Posts837,957
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
This from this month's MGOC Magazine.
The MGF is very sensitive to both tyre brand and tyre pressures. It appears that Toyo have applied some changes to the T1R's at September 2014 whether manufactured in Japan or at their new facility in Malaysia. So owners of MGF's who have replaced the rear set (quickest to wear) with post Sept 2014 spec tyres have encountered problems with handling that have been solved by fitting new front tyres to the same revised spec.
Obviously Morgans may not have such sensitivities to tyres, but it's worth knowing if you run Toyo Proxes T1R's that there is a difference either side of that date.
Posts: 61 |
Hi All I have fitted on 3 car T1R,s and currently very happy with the way the tires behave. I always fit in sets in case their is any difference in production. All mine fitted before mid 2014 All 3 cars handle very nicely and have good grip, even under heavy loading. Wear rate good not to soft.
Phil C Morgan Plus 8 4.0 Morgan 4/4 4seater 1.8 Volvo XC70 D5 220 Mazda MX5 2.0 Sport
Posts: 184 |
Thanks for the info.
David, 2001 4/4 4seater with TOYO Proxes T1R's
