0 members (),
317
85
Topics49,880
Posts837,760
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
I know  tanks for the movable water ballast.
Posts: 2,361 |
I know  tanks for the movable water ballast. Hmmmm now that's an idea!!!
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,361 |
The need for the carry case    I hope this makes sense now
Posts: 9,548 Likes: 133
Posts: 9,548 Likes: 133 |
A pump? But what of........ Petrol pump to fill the tank? Here we go again...haven't had a correct guess yet!
Posts: 14,009 |
Ah....the tank scavenger!
Posts: 2,361 |
Guys if you look back you will see I've added a fuel tank drain. I measure what goes in, then after each session I drain the tank. Working out what I've used againt track distance and how many laps, I can work out mpg and how much I'll need for the race etc
Posts: 4,896 |
Guys if you look back you will see I've added a fuel tank drain. I measure what goes in, then after each session I drain the tank. Working out what I've used againt track distance and how many laps, I can work out mpg and how much I'll need for the race etc Why not one of these flow meter , won't the fuel used vary track to track and depend on practice or race and conditions, with this you could see real time. Unless your weight is an issue, the car I mean.
Adrian
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
If the weight of fuel is such an issue it makes me think that either this car will be right at the bottom of the allowed weight range - if there is such a limit - or that it uses so much fuel that running out before the end could be an issue....
Posts: 2,361 |
Guys if you look back you will see I've added a fuel tank drain. I measure what goes in, then after each session I drain the tank. Working out what I've used againt track distance and how many laps, I can work out mpg and how much I'll need for the race etc Why not one of these flow meter , won't the fuel used vary track to track and depend on practice or race and conditions, with this you could see real time. Unless your weight is an issue, the car I mean. Yes the fuel usage will alter from track to track. This is the best way to monitor it for this reason
Posts: 2,361 |
Both reasons are correct but being as light as possibly in our class is the main reason
