3 members (TBM, MJF, Montegue), 233 guests, and 52 robots.
+8Rich 79
Luddite 50
Posts837,932
Page 37 of 53 1 2 35 36 37 38 39 52 53
Seems the starters flag is almost in sight.
Yep - 2015 licence application has been processed - just waiting for delivery.
Emailed Chris Bailey last night to get at least one slot at the taster day (shakedown & dry run the new transport setup).....
So yep - nearly there - an epic double car complete nut and bolt rebuild.
Still need to sort valuation for insurance .... ?!?
+1. Good to see Swanmog helping F B would be proud!
Hopefully will see you at the Taster Day! thumbs
Brian told me today they would be there. The cars looked really god in the metal today
Yep - filled in the applcations last night!!
Whoop Whoop!!
John - what did you think of the Yellow and Grey combination?
The colour combo is stunning, so much so your mum was showing it off plus her handy work on the white leather & I forgot to leave the car keys with her.
20 mins later down at the Eden shopping centre I realised they were in my pocket!!
I guess that was a KRAFT moment. Good luck at Curborough & I hope the clutch issue is resolved.
The blue & white car sounds fabulous.
FB should be impressed as well as proud, another day in the office tomorrow, should help to get the cars sorted, time getting sort.
And as for the colour of Woodstock you definitely will not miss it on the track.
The Mogworks team are doing a very good job on the two racers.
Phil C
Morgan Plus 8 4.0
Morgan 4/4 4seater 1.8
Volvo XC70 D5 220
Mazda MX5 2.0 Sport
Update 50 - Trailer lift, Rolling Road and Power!!
Over the last few weeks there has been a lot going on - over Christmas we dropped our new trailer back at PRG to have a second deck system installed - we had spec'd our trailer so we can fit both cars in and we've been designing over and over different systems to enable us to put both cars in.
We wanted something simple yet effective.... having looked at just about all the options we could come up with - in the end we have decided to go with the PRG option of a custom fitted electric hydraulic lift. Easy to use and effective in its operation.
You can also see for the first time the way the trailer colour coding works with the car.
The system uses a wheel spectacle on hydraulic rams each side. You can see it on the floor in the picture below.. the trailer has been fitted with small low angle approach ramps at the rear to allow the car to articulate up without the rear of the car digging into the floor.
So you need to reverse the first car in.
The front wheels then rest in the spectacle ready for lifting.
We have made straps for the front wheels to hold them into the spectacle for safety.
The ability to raise the car just by pressing the lift button is going to be such a relief at the end of the race day. We would have settled for a hand pump and we are somewhat spoilt by the fact this uses an electric pump.
This ramp and lift system also gives us a bush workshop which gives us a way to work on the car effectively if we need to.
Engine set-up
Northampton Motorsport our engine build partner got in touch to say they had a cancelled slot only a couple of days after we let them know we were ready. Troy's been looking forward to setting this engine up for a while......
First up is checking all the sensors, their operation and the ECU operation.... a few small minor electrical gremlins were all sorted and it was all set for first start.
Troy fired the engine up with a generic map and started the running in procedure... several hrs on the rolling road with initial set-up happening whilst taking the engine through a pre-determined rev pattern proving the internal loadings to run in the cam and all the bearings.
At half time the oil was dropped out and the filter changed - inspected.
With that sorted the main tuning activity kicked off in earnest with the revs rising as the hrs went on.
So the power!! - its all about the power??? isnt it
The graphs below are not the final run (a couple of hp less) but the tables are from the final run....
The headline is:
265 bhp @ 8200rpm
182 lb-ft @ 7200rpm
Good news is this is the most powerful Zetec-E engine Northampton Motorsport have built or tuned. Downside is this means that it moves me from Class 9 to Class 10 in the Sprint series which is going to be tough!! - Oh well.....
The power curve is more of a line which is great to see which means the engine is very efficient.
Below is a comparison of the power curves from the 2013 race engine Northampton Motorsport produced for us which was on twin 45's.
Last weekend I had a chance to drive the Blue and White car a bit - lets just describe the engine as Angry... its a kicking, spitting angry engine with a short fuse... its the sort of engine that revs up quick and dies just as fast... it would climb out of the engine bay and beat your face in and then run off with your girl if it could...... perfect!!
Another great write up, Andrew- keep 'em coming. Let us know how you get on with the big boys in Class 10. thumbs Gerry.
Gerry
+1
