4 members (CRL, Mike D, TalkMorgan, DaveW), 175 guests, and 63 robots.
+8Rich 70
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,884
Posts837,843
Gyp
Jeremy, you'll miss the sound of those diesels reverberating off the tunnel walls!!
WR142LL Offline OP
Originally Posted By Peter J
I thought that Brunel's broad gauge also allowed more headroom...
How much extra height is needed for the wires over the standard loading gauge?
Peter - they are having to demolish and replace or raise the deck of more than 100 bridges at huge expense. Most of these it is not necessary - if out in open countryside we will not be stopping trains underneath so a gap in the contact wire could be an alternative (as long as a technical issue with pantograph contact could be sorted) but it's public money so no ones really bothered.
Graham -yep I'll certainly miss the 2250hp at full chat. Might have to tape the sound and play back during each transit !
Cheers
Jeremy
2009 4/4 Sport Green
And nothing else !
WR142LL Offline OP
And they're having to dig DOWN through Sydney Gardens tunnels in Bath due to the World Heritage status of the stones !
Jeremy
And nothing else !
Formerly known as Aldermog
What about the Severn Tunnel....a bit longer than Box and notoriously wet. Copper wires overhead don't like water as Eurotunel has found out and that is with a modern tunnel that is essentially dry.
When Portillo was in the Severn Tunnel they lifted a manhole cover and there was a raging torrent under the track. If I remember that correctly.
WR142LL Offline OP
**** Anorak alert **** Anorak alert !
13 MILLION GALLONS of water pour through the Severn Tunnel every DAY ! If Sudbrook pumping station breaks down we have 3 mins to get out or we're all goners !!
Yes NetRail bosses have confirmed to me that Severn Tunnel will be "challenging" not only due to water but also dilute sulphuric acid (diesel exhaust plus water vapour) which wears the rails out in 7 years rather than the standard 25 years.
However the Severn is a problem for 2016 or 17. Will also be chaos when work commences.
Jeremy
And nothing else !
Perhaps rebuild the Severn Rail bridge?? smile
