7 members (IcePack, SwissMogFan, Graham, G4FUJ, Simon, Julian BB, +8Rich, RichardV6), 341 guests, and 29 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
Page 208 of 1,342 1 2 206 207 208 209 210 1341 1342
You must have driven past my works place... smile
You should have said Graham, I'd have given you a wave englandwave
2008 4/4 1.8 Duratec
Drove to Mogworks so they can work on the car dials that are misitng up.
Enjoyed the sunshine on the way
Are they putting silica gel in the clocks then?? smile
No drying them out with a hairdryer & trying to find the leak that lets water in.
As the car is dark blue I drive with the lights on so general public see me & the dials mist up rapidly.
Formerly known as Aldermog
Quick blast over to Gillingham (Dorset) to natter to Milligoon about many Mog things.
We discovered that the Plus 8 and Roadster share the same windscreen angle, the same angle on the rear deck but the rear underside of the Plus 8 is nearly 2" higher than on the Roadster at the base of the numberplate. We also found that the edge of the runningboars is lower on the Plus8 than the Roadster by 1"
We have no idea what all this means.
Black Rat
Black Rat
I think it means they are different cars rofl
Keith
2013 narrow bodied + 4 Ruby.
l
+1! happy3
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
thumbs rofl rofl
And did you measure anything else Peter? Like the dimensions of the cockpit? That would have a bearing on cockpit turbulence. And clear up once and for all just how much wider is the Plus8 to the Trad.
John,
across the inside of the rear wheel arches the Plus 8 is 4.75" wider.
I didn't measure in other places and compare, but a quick check shows between the inside of the doors above the door locks is 52" is and from the top of the padded edge of the front of the cockpit to the backk is 45". Would anyone like to compare their modern Trad?
