6 members (Alan Patterson, CharlieB, sprinty, hillclimber, gomog, hugo), 231 guests, and 26 robots.
+8Rich 94
John V6 50
Posts837,998
rockabilly john
Page 5 of 5 1 2 3 4 5
don't forget the tight fit of the fenders.
Agreed, they would be a tight fit but spacers or mounting hole elongation could cure that without too much difficulty. Just a case of would it all be worth it?
SBM Offline
Higher unsprung weight would be my first thoughts. Maybe a bit too much bounce felt at the wheel?
There is a school of thought that goes along the lines of imagining handling is a circle, in that whichever aspect is changed, it needs something else changing to keep the circle. All that ultimately happens is that the circle gets a larger diameter.
Personally speaking, I'm happy with the handling. I don't feel a pressing need to get around any corner a little quicker as I can scare myself quite well at the speed I drive at now!!
WW11 MOG
WW11 MOG
I run 30psi on my front Avons and understeer isn't really an issue anymore. 25 psi on the rear, which I am due to replace with another Yokohama Bluearth, as recommended by Mark Reeves....who is one person that should be in the know
I replace the Yokohama tire by a second yoko, and following a puncture I wanted to test another brand toyo cf2 without satisfaction, the two grooves of the tire tend to follow the longitudinal grooves of some road coverings, I will back again very soon a yoko.
