1 members (gomog),
299
Posts837,997
Posts: 215 |
don't forget the tight fit of the fenders.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Agreed, they would be a tight fit but spacers or mounting hole elongation could cure that without too much difficulty. Just a case of would it all be worth it?
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Higher unsprung weight would be my first thoughts. Maybe a bit too much bounce felt at the wheel?
There is a school of thought that goes along the lines of imagining handling is a circle, in that whichever aspect is changed, it needs something else changing to keep the circle. All that ultimately happens is that the circle gets a larger diameter.
Personally speaking, I'm happy with the handling. I don't feel a pressing need to get around any corner a little quicker as I can scare myself quite well at the speed I drive at now!!
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
I run 30psi on my front Avons and understeer isn't really an issue anymore. 25 psi on the rear, which I am due to replace with another Yokohama Bluearth, as recommended by Mark Reeves....who is one person that should be in the know
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
I replace the Yokohama tire by a second yoko, and following a puncture I wanted to test another brand toyo cf2 without satisfaction, the two grooves of the tire tend to follow the longitudinal grooves of some road coverings, I will back again very soon a yoko.
