Topics49,901
Posts838,046
Posts: 987 |
Spanner juggler designed and fitted to his car and mine an adaptation of a Caterham engine cover which sits on top of the duratec and now keeps water out when the car is washed or goes through a rain shower.
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
Penetrating oil has worked for me on zetec. Go carefully though with the spanner as said before
Posts: 213 |
Rob - good idea of a cover - any details of it for the Duratec - assume it would fit a GDI?
Richard +4 GDI Connaught Green, 2014 Magnolia
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
I don't think the two are similar enough to be compatible, but it's simple enough to make one up if you can manage a sheet of aluminium.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Another reason why the GM Ecotec engine is such a good solution for Morgans, they have a neat waterproof cover that keeps all the water and crap out of the spark plug well.
Posts: 213 |
DaveW/Tim - thanks for the photos - like the idea of a cover after seeing these - something has gone on my 'to do' list!
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Tim, Have you moved the indicators to the wings?
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
A quick check this morning after this post to see that my plugs were all ok (I remember seeing another Duratec Morgan in my local garage with a plug stuck). I’m puzzled. My question is… If I have no louvers and the car rarely gets caught in any rain, how does so much moisture get to the plugs? I’m often under the bonnet and have never seen a wet rocker cover (maybe because it’s usually warm enough to dry any water). So could this just be condensation from moisture laden trapped rocker fumes around the plug as the engine cools and the ambient outside temperature is low. Just poor atmospheric sealing on the underside of the rocker cover?
Roger 2011 Plus 4
Posts: 2,439 Likes: 71
Posts: 2,439 Likes: 71 |
Roger.Looks like you have had some water under there by the corner of the rocker bolts,mine were much worse but i did use the car all weathers.All the Fords have the plastic covers and is not an issue,whip them out once a year for best practice and i wouldent worry too much about it.
Em
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Here is my solution. I too use a modified Catterham cover. Dave will probably notice the neoprene strip used as an additional seal.
