I'm just showing my trial version spoiler which curves back towards the sump. I have made it in three pieces so as to be able to replace sections which might become damaged. It does seem to pull the hot air from the engine and in addition to the Mulfab radiator works well. It has been on for a year now .
Yes Ray it'd the poverty model! Mind you the horn button keeps falling out of my Motalita wheel. Not sure why but perhaps the horn button is meant to be an extra on mine too!
Bluetac! A small bit should hold the button and not make it a permanent fix. Also a cheap fix to match the " poverty theme"!
Before I got chance to try that the button dell out of the wheel this morning just as I set off for Oakmere's opened day. Went back home, had to put on a new connector to the wire & opted for two tabs of insulating tape folded back on themselves either side of the button. The only think that would appear to keep the horn attached is a very large o ring around the horn button so it would seem that is not keeping it tight for some reason. Oh well IAMS! It's a Morgan Sir (not that brand of cat food...)
Thanks for all the responses/comments to my original post. I have now ordered the full width Sport Valance from Cain and will remove the Over-riders to keep the classic look. I Will share the "before & after" image results once completed.
