0 members (), 265 guests, and 18 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
Page 3 of 4 1 2 3 4
Alexander #264371 03/04/15 07:51 AM
Alexander, Neat job.
Ian
Alexander #264382 03/04/15 08:03 AM
Rog Offline
Nice bit of work Alexander thumbs
Might be worth adding a couple of boots to those exposed terminals smile
Roger
Alexander #264424 03/04/15 10:33 AM
Thank you. Good idea about some boots.
Peter J #264436 03/04/15 11:06 AM
Hi Peter.
Be aware that modern(and not so modern) aircrafts use 28V DC, and 115V AC
The battery('s)are 28V from a type that might start a fire.
Rudolf
Morgan Aero8 S4 «Tango»
Fisker Ocean
Harley Davidson Livewire
BMW R100/7 , R100R
Moto Guzzi 254
Alexander #265898 08/04/15 08:57 AM
Ruby now starts like a dream!
I worked out why I was having trouble before - the cells were only half full, the acid having leaked down over the bulkhead.
I guess it's all the potholes around here... innocent
Alexander #266003 08/04/15 08:20 PM
Ouch how is the bulkhead? Time for some neutralsing solution & a good clean up?
Alexander #266004 08/04/15 08:21 PM
Just a thought is the rectifier over charging & boiling it off? Seems odd for it to just be bounced out.
John V6 #266895 13/04/15 06:30 AM
How would I tell? The voltage meter seems correct on the dashboard.
Bulkhead cleaned & neutralised before fitting the new battery. :-)
Alexander #266916 13/04/15 07:53 AM
Use a dvm across the battery terminals when the engine is running anything higher than 14.5vdc and you have a problem in the alternator.
Mark - No Longer driving
Alexander #266974 13/04/15 11:48 AM
I've just measured the voltage across the battery terminals:
Idle: 14.2V
5000 rpm: 14.2V
I've also noted that the dashboard meter reads significantly low! 13.8V (estimated as the graduations are not precise.
I don't think that's too high. The spec sheet says the following:
Alternator: 13.3 to 15.0 volts; no amperage limit
Battery Charger: 13.8 to 15.0 volts; 10 amps maximum; 6-12 hours approximate
Float Charge: 13.2 to 13.8 volts; 1 amp maximum current (indefinite time at lower voltages)
Rapid Recharge: (Constant voltage charger) Maximum voltage 15.6 volts. No current limit as long as battery temperature remains below 50°C (125°F). Charge until current drops below 1 amp.
The previous battery was very "discount"!
Page 3 of 4 1 2 3 4
