2 members (RichB, TalkMorgan), 193 guests, and 36 robots.
+8Rich 91
John V6 49
Posts837,978
Page 2 of 4 1 2 3 4
Q8morgan #276553 23/05/15 08:16 PM
VERY cool Q8 thumbs
Jays #276565 23/05/15 10:54 PM
Originally Posted By Jays
VERY cool Q8 thumbs
+1. Looks like the dash could get caught if you're too enthusiastic.
Q8morgan #276587 24/05/15 06:38 AM
Q8 I dont understand your comment you mounted your gauges on the column to make more leg room. Looks to me they are in an ideal position to take your knee caps off. No Speedo or is it track only? Great bonkers gear lever.
Tim
stantheman #276616 24/05/15 08:39 AM
Q
Q
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image.jpg1_zpshk1it4ic.jpg.html][/url]][/url]
The gauges were in the middle,so the passenger had very little leg room(knee rubs againist the gauges housing.
Gauges were temp/oil/volt & speedometer,speedometer wasnt connect(no cable to the trans).
So i decided to change them to something that fitted the look of the car & i wanted more space in the cabin.so i decided to have them on the coloum were they dont bother the driver at all.2 most important gauges are temp & oil.
The shifter was stock.when i changed to 2nd i would elbow the passenger & 3rd i would knuckle him in the knee, 4th i would black eye him.5th i would push him overboard...so i installed a short shifter & this hurst funky shifter stick.
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image.jpg1_zpsj1ndxfmi.jpg.html][/url]][/url]
stantheman #280847 12/06/15 09:45 PM
Q
Q
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image.jpg1_zpse3mstauq.jpg.html][/url]][/url]
Just installed a go baby go shift knob, i connected the button to the horn.
stantheman #280856 13/06/15 12:26 AM
Great start button.
stantheman #288030 14/07/15 02:41 PM
AMC Offline
Bought my M3W second hand last December. The standard gear knob recently started to rotate and on inspection I found that it was held on by friction and insulation tape; previous owner obviously kept the upgrade for the new Mog. No Morgan supplier could provide a wooden knob with the correct thread size. MX5parts.co.uk took 24 hours to provide a nicely weighted walnut effect knob that simply screwed on. Looks great and being wood effect it has a surface that will better resist wear.
Benfro Mog
AMC #288153 14/07/15 08:32 PM
Well post a pic please
stantheman #313965 23/10/15 11:36 AM
AMC Offline
The MX5 gear knob lasted less than three weeks. The vibration destroyed the composite material from which it was made and it did not have s metal screw insert so it just bounced off!!!!
Benfro Mog
Matty #316950 05/11/15 05:30 AM
Here's what I did. Matches the handbrake and generally looks more fitting for the M3W...
Page 2 of 4 1 2 3 4
