7 members (MJF, bmgermany, Jon G4LJW, Image, Aeromax51, TalkMorgan, RichardV6),
273
Posts838,002
Posts: 797 |
Help guys I am going insane The old girl has developed an new and infuriating rattle. After hitting any kind of bump in the road I get a rattle from the passages side and behind the seat. Sounds like a lose washer jumping up and down on the metal floor. Have tried everything. Stripped out the seats, searched high and low; nothing. Any ideas Off to dealer later today
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
A possible source for rattling may be the fuel pump(?) and hosings on the very top of the rear end, close to the outlet of the safety belts. I dismanteld the cover yesterday and put pieces of sponge (foam material) around the hoses and the upper cylindric unit. Much better now.
Posts: 112 |
,,BSA Goldstar,Honda CB1100R. Jaguar FTypeS Porsche Cayman S
Posts: 429 |
There is, what I suspect is a non return valve ((NRV )in the fuel system. It is on a little wobbly bracket, held with one screw to the wooden frame behind the passenger. If you flick it with your finger it rattles. Mine does. I posted a video of it on here some time ago but no one else had an issue. Perhaps this is your problem. It did take me a while to locate it as it sounds more serious. The video is still on my blog if it helps. http://www.westmog.wordpress.comGood luck Robert
Posts: 1,947 |
Does it rattle with a passenger? If so, take someone with good ears and mechanical abilities for a ride. It's very difficult pin-pointing the source of a noise and concentrating on driving as well.
Posts: 429 |
The trouble is Martyn, everything shakes less WITH a passenger. My particular noise only became apparant when I was on my own. Its funny that a car so noisy can still have irritating rattles...
Posts: 797 |
Thanks guys. Your so right about the passenger
Posts: 782 |
Could be rear boot has settled on the rubber and started rattling?
Posts: 1,562 |
Could be rear boot has settled on the rubber and started rattling? That happened to me - a short length of sticky back rubber positioned where the boot lid closes sorted it for me.
Posts: 797 |
Just out to check that
