2 members (TalkMorgan, verysideways), 336 guests, and 34 robots.
+8Rich 95
John V6 52
Posts838,014
rockabilly john
#266887 13/04/15 05:38 AM
Matty Offline OP
Help guys
I am going insane
The old girl has developed an new and infuriating rattle.
After hitting any kind of bump in the road I get a rattle from the passages side and behind the seat. Sounds like a lose washer jumping up and down on the metal floor. Have tried everything. Stripped out the seats, searched high and low; nothing.
Any ideas
Off to dealer later today
Matty #266888 13/04/15 05:47 AM
A possible source for rattling may be the fuel pump(?) and hosings on the very top of the rear end, close to the outlet of the safety belts.
I dismanteld the cover yesterday and put pieces of sponge (foam material) around the hoses and the upper cylindric unit. Much better now.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Matty #266896 13/04/15 06:30 AM
Hi +1
Davidg
,,BSA Goldstar,Honda CB1100R. Jaguar FTypeS Porsche Cayman S
Matty #266900 13/04/15 06:45 AM
There is, what I suspect is a non return valve ((NRV )in the fuel system. It is on a little wobbly bracket, held with one screw to the wooden frame behind the passenger. If you flick it with your finger it rattles. Mine does. I posted a video of it on here some time ago but no one else had an issue.
Perhaps this is your problem. It did take me a while to locate it as it sounds more serious. The video is still on my blog if it helps.
http://www.westmog.wordpress.com
Good luck
Robert
Robert
Grockle #266928 13/04/15 08:44 AM
Does it rattle with a passenger? If so, take someone with good ears and mechanical abilities for a ride. It's very difficult pin-pointing the source of a noise and concentrating on driving as well.
crazy2
Matty #266935 13/04/15 09:19 AM
The trouble is Martyn, everything shakes less WITH a passenger. My particular noise only became apparant when I was on my own. Its funny that a car so noisy can still have irritating rattles...
Robert
Matty #266958 13/04/15 10:56 AM
Matty Offline OP
Thanks guys. Your so right about the passenger
Matty #266964 13/04/15 11:08 AM
Could be rear boot has settled on the rubber and started rattling?
wiscos #266972 13/04/15 11:40 AM
That happened to me - a short length of sticky back rubber positioned where the boot lid closes sorted it for me.
Matty #266999 13/04/15 01:30 PM
Matty Offline OP
Just out to check that
