0 members (),
315
43
Topics49,897
Posts838,017
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Tough job as understood it but Dave W did it & it is I guess in his how to list
Just checked it isn't but some one posted about it on here
Posts: 5,587 |
Mulfab... Ah ! Thanks for that !
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Replacing the rear springs is perfectly do-able at home, you don't need a lift or anything, but it's a question of the more you are prepared to remove, the easier it is.
You need to remove the seats to get to the front mountings, and access to the rear links is a great deal easier if you remove the petrol tank. I did mine with the tank in place, but it was a bit of a fiddle.
The hard bit is getting the bolts into the front eyes. Assembly sequence is rear links, then fronts, then U bolts. When I did mine I clamped a steel bar to the spring so that it projected forwards, enabling my wife to stand on. That gave me enough room to poke the bolt through the eye.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
The hard bit is getting the bolts into the front eyes. Assembly sequence is rear links, then fronts, then U bolts. When I did mine I clamped a steel bar to the spring so that it projected forwards, enabling my wife to stand on. That gave me enough room to poke the bolt through the eye. Spot on! Plus if you need to move the spring forward and are short of a person to pry bar the rear shackle a ratchet strap round the rear brake drum and up to the crosshead means you can fine adjust the ratchet forward to align, never had one that needed moving backwards, never removed a fuel tank but have had a neighbour stand on the spring extension before now ;-). A simple but totally miserable job to do, it's all nuts and bolts but a pain, especially if you want to get 4 seater springs into a 2 seater as I did to my own! Different set on the springs means even more to compress. The only difference with Tim's method and it's a personal thing, is I do fit the U bolts before the shackles as I prefer to struggle with the shackles than fiddle with those outer U bolt nuts!
The only difference with Tim's method and it's a personal thing, is I do fit the U bolts before the shackles as I prefer to struggle with the shackles than fiddle with those outer U bolt nuts! Ah yes, it all comes flooding back me now! Colin's bang on here, the outer U bolt nuts are a complete and absolute PITA. Doing it the other way around may well be easier. I am not going to volunteer to strip and rebuild my rear springs just to find out, though.
Posts: 5,587 |
It has to be done somehow as I've ordered a pair from mulfab ! I wonder how many other bits need chucking to improve the Mog ??
Posts: 4,896 |
It has to be done somehow as I've ordered a pair from mulfab ! I wonder how many other bits need chucking to improve the Mog ?? Probably throw the shockers away and fit Rutherford AVO's (Mulfab can supply) To add Pair of Brake Reaction bars and a Panhard Rod.
Adrian
Posts: 5,587 |
It has to be done somehow as I've ordered a pair from mulfab ! I wonder how many other bits need chucking to improve the Mog ?? Probably throw the shockers away and fit Rutherford AVO's (Mulfab can supply) To add Pair of Brake Reaction bars and a Panhard Rod. Got adj shocks front and back , reaction bars and Panhard rod !
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
It's a strenuous job, but not technically difficult. I didn't touch my tank.
Posts: 1,415 |
[quote=madmax]It has to be done somehow as I've ordered a pair from mulfab ! I wonder how many other bits need chucking to improve the Mog ?? Probably throw the shockers away and fit Rutherford AVO's (Mulfab can supply) Our AVO's are to our own spec and not Rutherford Simon @ Mulfab
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
