6 members (Alan Patterson, nick w, Barry M, Pittsartist, Anonymouse, Morganmike), 298 guests, and 33 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,035
Page 4 of 4 1 2 3 4
Lodge Baker #264242 02/04/15 06:54 PM
Welcome to owning a special car. I also have an ivory white car, though a 44. Like you and many others looking forward to the better weather.i do venture out top down even when it's cold. They are meant to be used. Enjoy
2014 Morgan Ivory white 4/4
Hamwich #268945 21/04/15 09:00 AM
I got this one but no instructions came with it and i have never used a grease gun before - i understand it does not take cartridges and i have to spoon feed it? If so how do you get plunger inside the tube to stay down when feeding it - Sorry to be a pain and asking probably a stupid question!
Lodge Baker #268951 21/04/15 09:32 AM
Depending on the model of grease gun you have, there should be no need to spoon feed the grease from the can into it! The can should have a disc on top of the grease and you push down the open grease gun into it and it should fill up. The plunger should have a ratchet to hold it fully compressed whilst you do this. DONT press the ratchet to release the plunger until you have put the end back on the grease gun! Been there...done that...very messy!!
Lodge Baker #268955 21/04/15 09:51 AM
If you have a Wanner type gun, the plunger can be pulled back towards the bottom of the reservoir and then held in place either somehow with a proper Wanner you put one link of the chain into a little slot on the base of the gun, on rod type guns you move the rod sideways, play about with the mechanism to see how it works BEFORE you put any grease in.
Then (assuming the gun is empty of grease) the sequence is:
1. Remove the top of the gun from the reservoir.
2. Invert the gun over the tub of grease, centralising the reservoir over the hole in the plastic plate
3. Place the reservoir down onto the plate and hold it in position
4. Release the chain/rod from its latched position but DON'T LET GO!
5. Push the reservoir hard down onto the plate, forcing grease up into he reservoir, at the same time pulling the plunger back into the reservoir so as to give the grease space to move into. The idea is that you are trying to get grease into the reservoir but not air pockets.
6. When the plunger is fully retracted, latch it to hold it in position
7. Put the top back on the gun.
Last job is to expel any spare air, there should be a little valve at the top, you need to release the plunger to squeeze the air out.
In use, the plunger should be free to squeeze the grease up the gun. When you are not using the gun, lock the plunger to relieve the pressure on the internal seals of the gun.
Sounds complicated, but only takes a moment to get the hang of it.
Hamwich #268966 21/04/15 11:16 AM
Got it thanks very much - now working it. I was being too gentle with it!
Page 4 of 4 1 2 3 4
