10 members (Mike D, Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog),
245
58
Posts837,969
Posts: 120 |
Does anyone have strong views on the pros or cons of either ?
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
For a modern engine running a tank of super unleaded every 3 or 4 tanks of regular fuel helps to keep valves, injectors and so on clean, so it is said.
I find no difference in performance so buy Shell, BP or Esso regular fuel. I do not buy Supermarket fuel.
Posts: 4,896 |
Most regular branded fuel nowadays has around 4% Ethanol I believe, horrid stuff, even for cars supposedly built ethanol tolerate after 2011. I use higher Octane in the Morgan and Cooper S and yes it 10p a litre more but find I get better mpg around 10% and it actually works out slightly cheaper, non branded is worse for ethanol content and often will have few if any additives for cleaning.
Adrian
Posts: 1,947 |
<Dangerous Suggestion> Fill a can with Super, and a can with ordinary. Spill a small puddle of each on concrete, and light!
The Super will burn noticeably differently, a lot more uniformly, and faster. Whether your engine is bothered though I could not say. </Dangerous Suggestion>
As for fuel, my local Shell usually matches the Tesco in Watford and can be the cheapest non supermarket fuel in the country. But it a bit of a bun fight unless you fill up at weird times. I do, but living 5 minutes away, hardly a problem.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
"I'm sorry officer but Martyn suggested I try this petrol comparison and before I knew it......"
Posts: 1,562 |
I must admit I always go for Super Unleaded , I like to think I am giving it a 'treat'
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
The S&S people as well as all bikers I know go for the highest octane rating possible, shy of aviation fuel, which almost costs twice as much!
Posts: 870 |
Aviation fuel is either Jet-fuel (i.e. kerosene) or AV-gas (i.e. leaded petrol). At least those are the two aviation fuels I see.
Leaded petrol. Kills cat convertors on demand!
Posts: 870 |
Yup, that's why I mentioned it  Edit: And Jet fuel is basically kerosene, and therefore in the same category as diesel. It too will kill an S&S V-twin fast.
