1 members (+8Rich),
284
32
Posts837,992
Posts: 870 |
Got any 2 star? From the wink, I assume it was something taking a good-natured jab at me, but I honestly don't get the question. I blame the language barrier here. Or the time of night. Or perhaps both.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
No, bollocks to the fuel. A certain cool damp morning when engines just run beautifully. Is this water injection? No, just damp leads.
Posts: 1,947 |
From the wink, I assume it was something taking a good-natured jab at me, but I honestly don't get the question. No jab at anyone. The wink was just to show I knew it to be a rather silly question but when the normal offering was 2 and 4 star, two would have suited it well enough. For students of history, 2, 3, 4, and 5 star were available, with early +8s being set up for 5 star. Later on, 3 star was discontinued, then 2 star was 'replaced' by unleaded with I think super unleaded only appearing after leaded had ceased.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Posts: 870 |
Oh, I see. Thanks, Martyn. I didn't know that stars signified a grade earlier on.
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
S&S recommend a minimum of 91 octane in the workshop manual but don't state the units used so presumably it will be the American version so is equivalent to a minimum of 95 in Europe. Given the M3W's tendency to pink, I run on super unleaded whenever available but don't actually worry too much about putting ordinary unleaded in if that is all I can get. There is a distinct possibility that the pinking is largely down to excessive heat in the cylinder heads due to the ultra restrictive standard exhausts rather than a high compression ratio so the problem may go away with a change of exhausts (or removal of the baffles) mine certainly pinks much more in warm weather than in the winter so heat seems to be an issue. Last time that I was researching fuels was a long time ago and primarily for racing two stroke engines when the ACU had relatively recently mandated that super unleaded pump fuel was the only permitted fuel. It caused much wailing and gnashing of teeth amongst those who had their compression ratios and jetting set up for Avgas 100LL. Once people had sussed out the set up for super unleaded and learnt to not bother trying to read plug chops then power ended up much the same. The information I got at the time was that although Avgas is higher octane, it is designed to work in a relatively low compression, slow revving engine and at much higher altitudes than automotive fuels so isn't and never was the panacea for high performance cars and bikes that many think it is. If you do want proper automotive high octane fuels then they are easily available, just not at filling stations and only at a price! Try Sunoco or WP-Motorsport for some eye watering prices and if you've ever been in a holding area with all the engines running this type of fuel then eye watering is exactly the description of the exhaust given off. One of the big advantages of the race fuels is that they are as near as possible exactly the same batch to batch unlike any pump fuel which varies depending on time of year and what was available on the day at the refinery to make it from. It will also change depending on age as the tanks will not be kept completely sealed unlike the drums that race fuels are delivered in. Another big advantage of race fuels is that the organisers can tell you which one to run and a simple test can reveal if you are running something more exotic or are doctoring the control fuel. Not that I would have any experience of such things but at one time adding toluene or xylene to super unleaded allowed higher compression ratios so gave more power but wasn't detectable as they were only doing simple chemical tests on fuel samples that only showed that you hadn't added anything that wasn't already likely to be in the fuel. Later they started doing actual octane testing which meant more creative thinking was required and the cheating got more expensive. Later still the mandatory race fuels became compulsory in the higher level series which levelled the playing field somewhat.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
It seems that high zinc levels oils are not recommended with exhaust catalyst for the long term.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
As a poor apprentice in the 1970's my Mobylette would not keep up with the FS1e's and SS50's of the day so things had to be done.
1. Fuel was a mix of 4 star and toluene with a dash of castor oil for that bit of extra lubrication. 2 A small electric motor with a model boat propeller was mounted into the carb. inlet and wired up to the headlight. 3. Engine ported and balanced. 4. Handle bars replaced with clip ons.
At the traffic lights slide back onto the luggage rack turn the headlight on and give it death.
It didn't last long but it wasn't half a giggle.
Posts: 1,947 |
It seems that high zinc levels oils are not recommended with exhaust catalyst for the long term. Yup, google ZDDP and you'll learn more. Most, if not all oils aimed at the modern car user now have a low level of ZDDP to protect the catalytic converter. I believe Mobil 1 Racing is the only top end oil with a higher level of this additive.
Thank you for the correction Martyn épuration. I thought valvoline itself is compatible with the catalyst after verification. I had found an exotic brand of oil with a high ZDDP rates and other special additives Motor not recommended for catalyseur.
I use only BP SP98.
