0 members (), 305 guests, and 31 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
BertR Offline OP
Last autumn I reported on this forum, that a plastic radiator part had cracked on my Roadster (2009). I decided to go for an aluminium radiator from Mulfab. The replacement, triggers one to look at the temperature gauge more often. It struck me how low it actually reads; normally it reads well below 80 C, more like 75 C.
I decided I wanted to know more and after a drive I stuck a thermocouple between the coils of the radiator and measured 90 C. After idling for a few minutes, the fan switched on at 95 C.
The measured temperatures look normal too me. Can anyone on the form confirm the temp values I measured?
My conlusion is that temp gauge just reads about 15 C too low. Has anyone seen this before and can this be easily corrected?
Thanks for thinking along!
Kind regards,
BertR
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Do newer cars still have voltage regulators/stabilisers?
Drive on the Wild Side
Temp gauges are notoriously inaccurate, go on the thermo couple readings, I believe that fan kicking in at 95c is about right.
Adrian
Morgan seem to have forgotten this with mine just being cold, normal and hot smile
Kind regards,
BertR
I have owned 2 2008 +4's at different times, both are as you report, a friend recently bought a 2007 and it's the same, another has a 2011 car and his is identical. Two of us have Mulfab radiators and the dash gauge reading is the same. Everything points to an under reading gauge. We all just use it as a crude guide and not to be trusted, a little like the fuel gauge, the time to worry is when it reads above the 'normal' daily reading.
BR Colin
E
E
These days guages are nothing more than part of the in car entertainment system.
rofl
