Topics49,901
Posts838,044
Posts: 62 |
I'm going to wear out this forum with my newbie questions but here is another one. Since I bought the '70 4/4 car it has never gone above 45 mph while I was busy tending to minor things. Yesterday I had the chance to drive it at a decent speed. I got it up to 76 mph by GPS( the speedo doesn't work yet). It ran great and held the road well with what appears to be plenty of power left if I want to try it. However, at about 46 mph it developed a severe whistling noise. I depressed the clutch and it didn't go away. I backed off on the gas and it was still there. It continued to make the noise even up to the 76 mph figure. It almost sounds like a metallic ringing noise but for the life of me I can't figure it out. I taped up any firewall openings, the windscreens rubber area, windwings, bonnet belt, and any other areas where I felt that the air could be causing the noise with no positive results. Any ideas or am I going to be trying to live with this forever? The wife won't ride in the car with that noise so I have a serious problem! The engine when reved up at a standstill is very quiet with little valve train noise and the are no obvious mechanical items that are loose. I have had it on my lift for a couple of weeks while I was detailing the chassis and engine bay and during this time I tightened all hardware and carefully inspected everything there. Nothing seems out of place. Once the road speed drops below 45 mph the noise goes away. I think that I can rule out the gearbox and engine so that is good, but where else can I look. Obviously this is not a common problem but any hints would be appreciated. I'm open to any ideas. Could it be something simple like brake pads etc.? The wheel bearings appear good and the tires and wheels are nearly new. The front suspension was rebuilt a couple of years ago. I replaced the air cleaner element recently but I can't see how that would make this noise with air going through it at a higher load on the engine. I suspect that it is some odd thing that is taking place and I hope that someone has had this same problem.
Mark 1970 4/4 Morgan Two '53 MG TD's 1949 MG TC 1988 Porsche Boxster
Posts: 1,127 |
Hi Marcus, it may sound a little bit weird, but: try to tape the gap between headlamp & chrome trim... If ok then, add a stripe of n..pr..e (mind: this word is reserved exclusively by Dave.W. here).  Hope that'll help
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 62 |
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Mark, my 96 +4 did that and a new headlight seal stopped it
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
My + 8 does the same, never tried to find the cause.One day I will. 5 previous morgans all quiet, strange.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Self adhesive strip of neoprene inside the gap will stop it.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
We used to hear the whistle but now we have throttle bodies and a sports exhaust it seems to have gone away
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I have whistling in my +8. I think it's simply the air passing over the screen - but I've tried disrupting the airflow when driving and can't seem to find the spot that's making the noise.
+8 4.8
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
Side pipes are an instant cure for all other noises.
Martin (Deano)
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
I had a whistle and it went when I changed the position of the wing mirrors. You can swing the bracket in (or out) by pulling the mirror arm (forward or back against the base as it is spring mounted) and try a different position. I was amazed at the difference.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
