1 members (Graham, G4FUJ),
248
34
Topics49,911
Posts838,152
Posts: 107 |
I OWN A 2002 AERO WITH 8000 MILES ONLY .THE ORIGINAL POWER STEERING PUMP HAS JUST FAILED ? IVE BEEN TOLD BY THE FACTORY I MUST PURCHASE A RETO FIT ELCTO/HYDRAULIC CONVERSION KIT AT COST PRICE (£319)WHICH I INTEND TO FIT MYSELF.THE FACTORY HAVE ALSO SENT A DVD INSTALLATION GUIDE ,HOWEVER IT DOES NOT SHOW HOW TO REMOVE THE L/H WING. HAS ANY MEMBER SUFFERED THE SAME PROBLEM OR HAVE ADVICE ON THE MATTER ...SIMON G
Posts: 123 |
Hi Simong !The pump on Morgan from mini .Common failure.Some of the new pumps fail.basically it dermot.To remove wing undo 6 bolts,disconnect headlight,disconnect splitter,front grill and that's it.
Posts: 107 |
Hi Yuri..my aero has the original mechanical power steering pump driven by the crank pulley via an extremly poorly engineered coupling ...are you saying that the retro fit electo/hydraulic replacement modification from the factory is the same mini pump which has caused BMW major problems latley ? ie.. lots mini owners with failed and dangerous steering.....I really do not want to be doing this job again....simong
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
Hi Simong !The pump on Morgan from mini . mini : the "weener", does it make that same noice as on my MINI??????
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
Suprised the mechanical pump lasted this long, they wear out quickly. Still means your car reallis genuine low mileage. Had this done on my s1, no issues following the work and I did 10k miles in 2 years so doubt you'll have issues.... It is noisy though....
Is the car under warranty? I claimed this as a warranty issue...
-------------- Maxxed out!
Posts: 2,825 |
Just to clarify for you simon, the pump is run on the s1 via a mechanical propshaft from the driveshaft. This isn't a good design and does basically wear out.
The fix is as you have been told an electrically powered pump. This is I think one from a rover of some kind. I had it done as I mentioned and it was a perfectly good fix and never caused further issues. The dealer cost for the fix was over 1000. As I mentioned this is a known s1 issue and if the car is under warranty you should pursue a claim if your warranty covers this.
Posts: 107 |
Thanks Mr Tony ...i guess my warranty expired 6 years ago, 12 months after i purchased my car..If i had driven 8000 miles in the first 12 months like most owners ,MMC WOULD HAVE THE PROBLEM ...surely this should have been a recall by MMC on safety grounds alone ?... NOT good for customer relations ...,however i love my car and cannot wait to get her back in good health....MY AERO S1 HAS A DOG TYPE COUPLING BETWEEN CRANK PULLEY AND PUMP WHICH HAS SHATTERED ;I MUST SAY A VERY POOR ENGINEERING EFFORT WHICH WAS DESTINED TO FAIL....I CERTAINLEY DO NOT HAVE A MECHANICAL PROPSHAFT FROM THE DRIVESHAFT AS IN YOUR CASE...? THAT does sound problematic ...
Posts: 290 Likes: 1
Posts: 290 Likes: 1 |
Peugeot 106's run an eletric pump if you need one
Fixing broken sh1t
Posts: 287 |
Mine does
Posts: 2,825 |
Hi simon, the arrangement you describe is probably the one I had, I'm juist not much of an engineer so the description I gave was me rehashing what the mechanic simplified for me. (Cerial will shoot me for getting it so wrong!) Sounds like you have the fix lined up though which is the main thing.
