Morgan Aero 8
1 members (Graham, G4FUJ), 248 guests, and 34 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#277586 28/05/15 07:57 PM
taffy Offline OP
I am having a problem for a couple of years now and its when the engine gets really warm it cuts out when I stop at lights,etc. The engine will restart straight away again but its a real pain. The car had a major service around 500 miles ago and I have tried keeping the fuel tank at least half full to ensure itsnot picking up any crud in the tank. Any ideas?
thanks
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Drive on the Wild Side
Just a thought, does the BMW engine have variable timing? It could be a dodgy camshaft sensor causing the ECU not to adjust fuelling correctly when dropping revs or if fly by wire throtle could have the same result if giving false voltages to ECU.
Adrian
Formerly known as Aldermog
I think it does...both inlet and exhaust cams are adjusted, BMWs "double VANOS"
Probably needs the attention of a BMW specialist rather than a Morgan one for that sort of complicated problem.
Plug in a code reader and see if any faults are logged
Mark - No Longer driving
taffy Offline OP
many thanks for the responses everyone. Off to a BMW specialist next week
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
This may sound crazy, but I wonder if it's vapour lock? Where does the fuel line run? Would it be worth wrapping the fuel line in tin foil just as an experiment?
+8 4.8
taffy Offline OP
Hi Neilda,
I was thinking of vapour issues to begin with - but thought it too "old fashioned" a problem, if you see what I mean!Its booked in now to get sorted!
thanks
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
It sounds very much like vapour lock - engine stalling when hot - but unlikely somehow on this type of engine. Will be interested to hear what the experts say.
+8 4.8
Taffy,
I was just looking up my notes on this problem and a possible cause is the MAF. Not sure if you have already lookded at this but if not the Air flow sensor MAF could be an answer. Owners of the S1 have experienced engine cutting out at traffic lights, going into limp home mode etc when this is faulty. Accessed through the cowl and a standard BMW part, £100 cost was mentioned.
Also Viper mentioned in a post some time ago about Brian Millers "stent" idea fitted to the rubber tube air supply which had collapsed thus causing the MAF to fail.
Let me know if you solve the problem
taffy Offline OP
thanks lightshere - sounds very similar problem!
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
