8 members (B3MOG, Scrambledsignals, t50, Ulfulf, TBM, JohnHarris, linklaw, brownbaker), 371 guests, and 41 robots.
Adam12 70
+8Rich 69
John V6 52
9,215 Registered Users
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,376
Posts813,550
Members9,215
Page 3 of 3 1 2 3
WW11 MOG
WW11 MOG
Here are photos of my rear tyre. Its probably run 60 miles!
Its a Yokohama A Drive 175/55/R15 77T, which apparently has a speed rating of 118mph - which I certainly didn't get up to. The tyre pressure was 25psi
Does it look to have overheated to you tyre gurus out there?
Should it have been pumped up harder?
By comparison, this is my Yokohame BluEarth, which has done around 300 miles, including 8 runs up Loton Park hillclimb
WW11 MOG
WW11 MOG
This is the state of my Avons at 5000 miles. They hung on well at Cadwell Park
I run them at 30psi
SBM Offline
The fronts are fine. The rubber 'snail trails' on the tread block tops are the surface rubber scuffing up & balling as a result of the cornering forces. It's similar to pushing an old sticking plaster off your skin, and nothing that a few road miles won't wear down.
Your A Drive rear tyre shows signs of being well scrubbed, but it's not showing signs of being overly hot in the photo's. Overheated tyres display signs of 'blueing' at the tread edges, which yours don't.
Was it over or under inflated? Difficult to say on visual alone, as there seems to be adequate wear across the tread area.
I think it was hot at the time it came to rest as the grass debris is 'stuck' to the tread ribber. If you've skidded across tarmac before coming to rest, that would answer that though.
Perfect answer Stringers, when mine look like that I clean them up with an old "Surfoam".
You old boys out there will know what I mean.
WW11 MOG
WW11 MOG
Thanks Steve. All the tyres were at the correct pressure when I checked them just before taking the photos last night (30psi Front, 25 psi Rear). I should have said in my post.
The pressures are what I've found work well on the road, hillclimbs and even a trackday at Oulton Park, but they were worked far harder at Cadwell Park than ever before as it felt as if I was sliding around most corners - the sensation was absolutely fantastic!
I didn't have any tyre concerns in the practice session, as partially captured on nippymogs video, but during the race the ante went up a serious few notches. I couldn't believe how competitive these 3 wheeler racers are. I have an awful lot to learn.....
I've Googled Surfoam, and I think I have one lurking in a drawer in the garage. Thanks Dab, will give it a go
Hi WarBird, hope you find one they work a treat, all the hill climbers and sprinters use them to clean up their slicks, works on road tyres too.
SBM Offline
Also good for haemorrhoids, but wipe with Dettol afterwards..
laugh2 thinking
Warbird could it be that your rear tyre was too new. Road tyres need "running in', say under 50 mph for 50 miles. I believe this releases something in the tyre compound which aides longevity.
There are likely plenty of unused spares which will be useless when the time comes.
Tim
laugh2 thinking
The Morgan-owning demographic is probably wincing en masse....
Stuart
Page 3 of 3 1 2 3
