8 members (M3WMW, JMcL, John Winn, TBM, Black Adder, Strathaven, bmgermany, RichardV6), 226 guests, and 32 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,124
#276310 22/05/15 09:31 AM
KBMOG Offline OP
I recently found the following items on the internet and am now considering fitting them to the M3W
http://www.kitspares.co.uk/index.php?route=product/product&product_id=709
As you can see they are a pair of headlights with a row of LED's around the lower half of the circumference to provide Daylight Running Lamps.
You will note that they are currently out of stock but I have spoken to them this morning and some more are expected in within the next 2 to 3 weeks.
As a result of riding motorcycles for years and the fact that the average motorist just does not see you, I usually run with dipped headlights during the daytime.
I thinks these would be a better alternative as they would draw very little current from the battery and place a much smaller load on the electrical system, which if you have are stuck in traffic (or running extra things like cooling fans or heated seats), can run the battery down very quickly.
Assuming they fit our rims, what do my fellow M3W owners think?
KBMOG #276316 22/05/15 10:04 AM
These look pretty similar and may be worth investigating at lower cost.
http://www.powerfuluk.com/products/land-rover-defender-lamps-and-light-upgrades/land-rover-defender-drl-style-led-headlights-%28-pair-%29.html
2014 +4, Le Mans Blue / Magnolia
"Meg" the Mog
The way I read KBMOG's lamps the price is for a pair , where as yours is for a single so actually more expensive ?
I think the idea is very good , but how do you wire the led part up ? do you just connect the led wires to the existing side light feed , or do something special to protect the leds from overcurrent etc ? electronics is not my speciality, but I believe you have to protect leds from too high a current or they easily go pop !
KBMOG #276326 22/05/15 11:04 AM
KBMOG Offline OP
The LED's would be wired up to the sidelight feed and would in fact take the place of the existing sidelights.
The LED's would only pull the current they require which would be minimal. It is over voltage that will kill LED's and these would be suitable for normal 12 volt electrical systems as per the M3W.
nippymog #276336 22/05/15 01:25 PM
According to the web page (blue wording below pictures) the price is for a pair, so they are significantly cheaper
"Meg" the Mog
KBMOG #280668 12/06/15 08:32 AM
hi KBMOG
i have bought a pair of DRL lights from powerfuluk.
Took the plunge and ordered and hoped they would fit easily.
Well, they have arrived and i have installed them. Very simple in deed, just 10 minutes a side, even for a muckanic like me
They do look quite modern! The DRL leds are much more "noticeable" than the normal sidelights which is what i wanted from them ( lucky that !!!)
The DRL lead has a connector attached which just plugs into the side light bulb holder ! Swapped over the H4 lamps from current lights. I am hoping that there will be an improvement in main/dip performance with the better reflector design in the new units.
Been wet recently so havent been out in the dark yet to found out how it all works.
photos were taken with cell phone so twas difficult to show the illuminated leds. Sort of worked. First pic just after installed. Second pic tries to show Leds on.
lights off
DRLs on
KBMOG #280670 12/06/15 08:42 AM
Can you advise the part description / number of these -- I can't easily see them on their website. Thanks
Robbie
2021 Plus Four -- Helga
211-WX-1433
KBMOG #280688 12/06/15 10:19 AM
SBM Offline
I think they are these Robbie -
DRL Headlights
KBMOG #280690 12/06/15 10:26 AM
SBM Offline
You can get an idea of the finished look from this racing ARV-6 as it hunted down Henry Williams at Rockingham recently..
Robbie #280703 12/06/15 11:20 AM
the ones i bought are from the link above for the land rover defender etc. Look the same as the ones in the last post
the pics in the ebay link shows the units much better than my attempts.
had no trouble ordering direct from them and had them shipped to NZ within a couple of weeks.
