1 members (gomog), 365 guests, and 39 robots.
+8Rich 103
John V6 63
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,250
MossyfromNZ
#280766 12/06/15 05:26 PM
Bosh Offline OP
I have just replaced the gearbox extension bushes on my 1992 plus four. This involved removing seats transmission tunnel and gearbox cover.
Having reassembled it, when I put the key in the ignition and turn it nothing happens. No sign of any instruments working, no starter relay click. The only sign of electrical life is that the clock is going. confused2
The engine started before I started reassembling.
Does anyone have any idea what I might have done?
Thanks
Cut out switch? Have you caught the red key? You can bridge it with one side of a pair of jump Leads to test, as the clock is running looks like the low current bypass is working but the switch could be off......especially as you have had the seats out!
BR Colin
Bosh Offline OP
Thanks spanner juggler that's exactly what it was. I had to remove the key to lift the carpet when I was fitting the transmission tunnel. That must have been it's last turn because the switch seems to be completely shot.
Temporarily bypassed and all working again
Thanks again
Glad to help and that it was a simple fix, I am sure you know this but you can put both leads on the same side of the cut out to get you on the road if you like, just means you have no cut out until you replace it. Safe miles.
Colin
BR Colin
On my 97 +4 that key was very sensitive. I did consider replacing it, Good options are on e bay as Mr Mog bought a basic cheap one. See GoMog
Were those cutoff keys standard on earlier Plus 4s then?
My '97 had one...
So did my 94 +4, probably all did until MMC started fitting cars with adaptive ECU systems?
BR Colin
My 98 +8 has one too...
Dave
98 +8 Corsa Red
74 MGB Red
