1 members (Carbuilder), 344 guests, and 27 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
1. With the boot insert out and the car firmly on jack stands I think it is perfectly safe to run the engine in second gear to check the belt (but not with the fingers?)
2. I think a better place to check the "center" of the front would be the lower A frame or A frame mounts, rather than the "number plate" The frames ARE jig welded. Spin the rear tire and make a reference line (Chalk?) on the circumference of the tire and triangulate from the front rear lower A frame mounts?
My cars number plate is centre mounted on the jig welded chassis. Even if it wasn't, as long as the target masking tape graduations are centrally positioned with the chassis, it will be OK. The number plate is just somewhere to stick the target, the back of the plate is in a good position.
As someone mentioned, check the rear wheel is mounted in the centre, some appear not to be on some early cars. If you use the laser level against both sides of the rear tyre and the laser dot hits the target equal distances from the centre you have aligned the rear wheel along the full length of the car, without the need to keep checking triangulation measurements, easy. Check the rear wheel is still aligned after tightening the axle nut fully, it tends to move.
Looking at moving machines is fine but working on them is a risk you decide on. I still have all my fingers after 40+ years in engineering.
