11 members (John V6, Graham, G4FUJ, MartinB60, RichardV6, GrumpyPa, +8Rich, High Hamster, Morganmike, TalkMorgan, JohnHarris, How), 301 guests, and 33 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,092
A new rattle from the exhaust today revealed itself as a broken shock absorber bracket.
When I see the thin material around the bolts I am not surprised.
Does anyone know if improved parts are available on the market?
4/4 2 seater 2001 model
You could try Mulfab
Martin (Deano)
It`s those bumpy roads around Bergen - wish I was there.
U
TM Photographer of 2008
U
Morgan have beefed them up, although I still managed to break one.
Ken
Hi Ken
Mine lasted 49000 miles.
How long did Your last, both Versions?
New Elms do a beefed up version beefier than the beefed up Morgan updated ones.
Mark - No Longer driving
This problem was addressed in the early 1990s by David Rutherford who produced a strengthened version with a three bolt fixing and an extra location that is welded to the end of the axle.
I welded a tab on the axle ends and drilled and tapped the lower shock absorber mounting so that it could be removed without cutting of the weld.
Tim Ayres at New Elms has the strengthed mountings; I suggest that you contact them for assistance.
Try Brands Hatch Morgan they had the new ones when my friends broke.
U
U
Hi Ken
Geir, the off side broke after 57500 miles. I replaced it with the updated one which failed after 8200 miles. The original type on the near side failed after 59700 miles.
Ken
Contact Trond Bråthen and ask about his air suspension conversion. It prevents bottoming out of the rear suspension. The original brackets then take much less load and you will be able to pass speed bumps at the speed limit.
Harald
Harald
