Posts837,991
Posts: 157 |
Can anyone advise on the best way to replace steering rack gaiters on a +4? Hanged if I can see how to get at the things....
Thanks
2011 +4 'LB' Indigo Blue, Heron trim Saab 9-3 1.8T Sportwagon
Posts: 27,835 Likes: 760
Posts: 27,835 Likes: 760 |
Posts: 157 |
Thanks John, I know that page...but it doesn't tell me anything about how to remove the rack to get at the gaiters...
He mentions undoing one end of the steering rod and doing that way.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
I need to check if there is anything special about Morgan's, but usually to change a rack gaiter is a simple job, take off the track rod end ( count the turns) and lock nut, and once the clips/ties are removed from the gaiter it slides off down the rod.. Unless I'm missing something?
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
You're missing something! Two track rod ends per track rod and the gaiters are in the centre
Ah.. Well trust Morgan's to do something different to every other manufacturer. Well corrected Dave, I must take another look next time I'm under there!
Posts: 157 |
I could cope with it if it was all in a line as per normal, but this has me stumped :-( Glad it's not just me...
