2 members (SailingTom2, Morganmike), 305 guests, and 36 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Page 1 of 4 1 2 3 4
Gulf44 Offline OP
http://www.williamsautomobiles.com/racin...nding-upgrades/
Anyone done any these for road use? Experience?
Looking for another Morgan!
Panhard rod is a good mod to locate the rear axle more accurately when cornering. DIY job for the reasonably competent mechanic.
http://www.mulfab.co.uk/our-products/14/steering-suspension/panhard-rods
Gerry
Drive on the Wild Side
The best and first to do is pan hard rod and brake relation bars, followed by Avo adjustable shock absorbers. If you want a comfort ride then it would be full Suplex kit up front. I believe Suplex are also now doing rear springs.
Adrian
I had my car sorted by New Elms using Rutherford components. Grand job!
2nd that, Darren at New Elms sorted a slight wheel wobble on my +8, by a re-aligning the steering rack to get the steering arms parallel. Great job.
Adrian
Totally agree. I fitted both the Panhard Rod and Reaction Bars and they are straight forward to do. (Just get some good drill bits). AVOs were an early (easy) upgrade as well and with a well greased front end - all good!
Certainly felt the difference going up the 'Hill' at Shelsley Walsh
Keith
On my older narrow Morgans I used Rutherford rear conversions and Spax shock absorbers.
The general consensus today is that Rutherford AVO's and Konis are better.
The Spax however transformed the ride and handling from the lever Armstongs.
Gomog do a test on the damping rates of various shock absorbers to compare.
For the +4 4seater I tried AVO's and found that Suplex front and rear with the Bilsteins to give a better ride. The problem was that I had weak rear springs on the +4 so perhaps not a fair comparison. The Suplex springs come with specially rated Bilsteins but they are not adjustable.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
I wish I could find two people to agree on the best spring / shock combination.
My 4/4 grounds a bit at the rear.
Before anyone says so I know I need to lose weight!
Any questions pm me.
As you can see from Henry's race car, we have sorted the suspension problems. We can cater for any budget, doesn't always have to be the most expensive.
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
Page 1 of 4 1 2 3 4
