0 members (), 327 guests, and 38 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Page 4 of 4 1 2 3 4
Yes Peter I did get my well laden M3W to ground on your drive. You are too scared to say Giulia is a big old unit!
I hope to get the 4/4 right but can I afford to?
Originally Posted By Hamwich
If I had a more modern car with better stock suspension, or if my driving was more on smooth 'A' roads or racetracks, then I guess the improvement would be a deal less apparent.
On Motorways, dual carriageways, and similar major roads of course, there's no measurable improvement. A stock car performs perfectly well on these surfaces and the Suplex system brings no benefit.
I sort of agree with that. Many Italian roads have similar characteristics to the English B roads.
I am sure that the latest production has improved springs. At least I would hope so after all the complaints in the 2011/2012 period for both front and rear springs.
My experience was a car with seriously low ride height when it left the factory. All springs were changed under warranty. I felt the car had too much body roll with the new springs and I felt that a sports car should at least be able to out corner a family sedan.
When I fitted the Suplex I noted the following:
less body roll,
lighter steering,
the car felt better planted on the road and could encounter mid corner bumps without skipping sideways,
and, the ride was much more comfortable.
Perhaps there are other solutions that would cost less and give all this but I suspect there would be compromises. My compromise was to accept a little initial softness in the front suspension in favour of comfort.
Can I outcorner the family sedan with fully independent suspension? Well at least they don't leave me behind! Certainly the car now handles as well as I am prepared to push it.
By all reports the new rear suspension kit will give a more supple and controlled ride whilst reducing body roll even more.
It all sounds good to me but I am not saying it is the universal solution either in terms of handling or budget.
Originally Posted By Mike Hughes
My car was a new 3.7 Roadster and the Suplex made a big difference.
Even my OH, as a passenger, was amazed at the change.
Same here. OH noticed right away the better ride and also feeling safer when cornering with the Suplex.
However I would not know what to advise as the variance in spring quality and spring rating seems to be a Morgan problem.
My friends 1993 +8 had the rear springs changed under warranty. He also had softer fronts with higher damping.
I had no problems with the various 1959 to 1976 4/4's that I owned.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
Originally Posted By Jays
Just don't expect the Suplex suspension to make a huge difference. On reflection on my Roadster I wish I hadn't bothered.
Other opinions are also available wink
Oh I agree.....if I'd still got my 4/4 I would have been singing the praises of Suplex. For some reason on my Roadster it made little difference apart from lightening my wallet!
Page 4 of 4 1 2 3 4
