3 members (DavidR, +8Rich, John Winn), 269 guests, and 28 robots.
+8Rich 94
John V6 50
Posts837,996
rockabilly john
#294809 07/08/15 06:53 PM
LarryS Offline OP
Has anyone tried using sound deadening material in the rear of the M3W? I was going put some on the rear facing firewall; however there is virtually no empty space. Next choice would be behind the seat back. BUT, I couldn't figure out how to get it out. I also would like to tape off the cracks back there to keep the dust down. Any help? LarryS
Formerly known as Aldermog
A sound plan, I used Dynamat on the Roadster, to good effect. I see no reason why it wouldn't work on the M3W
I will be using dynamat on my m3w all over ,it worked on all my other cars and van
A great idea and I celebrate it! However, it has come to my attention that backing the rear seat, while good and groovy, will be periodically ruined by removal as getting to the bevel box to drain and change the oil is now recommended for every oil change! It is SO much easier to have access back there this way!
Reason I mention this is that Morgan has now changed their recommended bevel box change intervals to the same as the engine oil. It is a good idea.
Charlie, Former Editor
Larry
There have been threads showing dynamat behind the seats. Blake did a sterling job but I stopped at behind & under the seats plus silicone sealing between floor & frame tubes. Simply sealing gaps behind the seats with aluminium tape will cut some of the noise & reduce dust inside.
http://www.talkmorgan.com/ubbthreads.php/topics/176831/1
Tim
Can you describe the sound you are trying to deaden?
Sound Deadening Instructions: 1. Do not run engine, 2, Do not move car.
Have you considered earplugs?
Or even noise cancelling headphones.............
Q
Q
Exactly
