2 members (MATTMOG, DCH), 276 guests, and 30 robots.
+8Rich 94
John V6 49
Posts837,994
rockabilly john
Page 1 of 8 1 2 3 4 5 6 7 8
It seems things are moving along on the Suplex 5 link rear suspension. Pre production sets have been made using the tooling and jigs that will be used in production.
I have heard from Peter Ballard and he has passed on the latest news.
The PreProduction2 was fitted to a 3.7 Roadster last week. Reports are that it transformed the car and that it can now use all that torque and power. The ride is so much better and it has much more grip in bumpy corners. Apparently an ex-Morgan race driver and dealer drove the car too, he was very impressed, could not fault it. According the owner he did drive it hard, very hard!
Spring rate progression and damping adjustment range are good. Roll stiffness progression also seems to work very well.
Peter tells me that they are doing a few minor mods to help manufacturing and fitting, then production. I hope to make it a project to get a set fitted before winter sets in.
They will be offering tuned Bilstein monotube nonadjustable dampers at the rear to match those in the RS up front, then also adjustable monotube dampers front and rear matched.
Prices are not yet decided and, as I said before, the fitting of the Suplex front suspension ‘Refinement System’ will be a pre-requisite as the front and rear systems are tuned to balance together. I understand that there will be a limited number of qualified dealers initially to ensure the correct fitting of the system.
I don't know who the owner of the Roadster is. Perhaps the lucky man will reveal all in due course.
I should mention that I have no financial interest in this product. I am just a satisfied owner of a car fitted with the Suplex front suspension RS kit, and I am passing on the news because I know many are interested to know what is being developed.
The attached photos are of the PreProduction1 set fitted.
Drive on the Wild Side
Sounds interesting, just need to get the cash together if I decide to upgrade it all
Adrian
Ray Offline
Sorry to say, at the moment it looks a bit Heath Robinson. Hope I am proved wrong.
Will there be a 4str variant?
Thanks Peter,
This looks a bit more involved than the Suplex RS front suspension job, but no doubt well worthwhile if you want a better ride, proper axle location and improved traction.
I assume the second photo is taken from the underside?
Not sure I quite understand the new geometry yet, are the leaf springs being retained?
Personally i don't mind the Heath Robinson look , it is kept out of sight most of the time anyway.
Andy G
1999 +8 , Indigo Blue.
E
E
Looking at this I assume the bottom 2 links attach to the front (leaf) spring hangers. It seems a natural place to attach them IMO.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
You sure it's not your roadster Adrian?
Martin (Deano)
I wish, but I suspect I may know who it is innocent
Adrian
I assume that two different springs are used to get a rising rate suspension. It is also interesting to compare the suplex setup with the Mogvette solution:
Harald
I think that the leaf springs have gone. I feel nostalgic already!
1992 plus4 connaught green
