3 members (bmgermany, RichardV6, Mick Annick), 196 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,124
Visited chum today who has the luxury of his own four point lift and was able to have a really good look at the underside of my 2009 Plus 4 . Discovered a strange little electrical component attached by cable tie to the front nearside axle tube .Can anyone tell me what it is .It is approx 6 x 1.5 x 1.5 cms and has a wavy piece of sprung steel at one end and two wires that go into the loom by the crank sensor.Sorry not able to take a pic as wife is away for the w/e and has the camera.
Many Thanks
Gerry
Verbum sapienti sat est.
Might be a road speed sensor?
Phil Egginton
1979 4/4 4 seater
If it's the gizmo that sits in a little 'cage', I believe it's the outside air temp sensor which will input the ECU for cold starting.
That's just me applying ignorant logic by the way. grin2
Well, here's the object in question.......
But here's the 'thing in a cage' which I was confusing with 'exhibit A'. This is tucked up behind the radiator amd I'm guessing may be the fan sensor for low speed/high speed changeover.............
Hi Dave,
Many thanks for your reply with pics . Exhibit A is what I was I was on about it is all clear now .
Regards
Gerry
So, we're all intrigued to find out what it actually is...
...FWIW I don't have one (04 built 4/4) so I feel left out thinking
It appears to be the ambient temperature sensor which presumably feeds into the ecu to determine cold starting procedure.
Don't feel too aggrieved if you are lacking this as it is just one more thing that can go wrong.
Regards
Gerry
