8 members (andymog1, cerealsurfer, Graham, G4FUJ, Paul F, SailingTom2, BertR, Image, ChrisConvertible),
222
38
Topics49,908
Posts838,123
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Fractured oil pipe spraying hot oil at 3+ bar all over everything?
Not a nice thought.
Electrical, every time!
Posts: 676 |
The Luddites amongst us with old cars like the mechanical oil pressure gauges. I have one in my Series 1 and has been perfect for 25 years. Keeping the oil from leaking out of various orifices of the engine and drive train is another matter though.
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 327 |
You should contact Ian John at Caerbont, the makers of all smiths gauges, they supply MMC with all thier gauges. He was extremely helpful to me when i wanted to install an oil temperature gauge. He will be able to help you with gauges and fittings that you require......however beware, morgan apparently have persistently sourced the incorrect oil pressure sender for the 3-gauge panel instrument you need his advice.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Lowflyer...check dates on thread !!!!
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Steve, would you mind telling me which guage you are using as I want to ditch it he clock and use a pressure gauge on my new Plus Four Thank you.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Lowflyer, do you know by chance the number of the correct oil pressure sender for the 3gauge instrument as it is in a 2014 4/4? Do you have this information also from Mr Ian John? This would explain a lot why my OPG is really not to use. Now it is April 2019 KEVFITZ haha
Posts: 37,486 Likes: 992
Posts: 37,486 Likes: 992 |
The OP has long since moved on from Morgan ownership.
Posts: 308 |
He’s concentrating a lot more on oil pressure these days! 🙄🤣
John 1936 Austin Seven Ulster Replica
I imagine he is As long as he's enjoying it.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Hi, as others have said I no longer have the Morgan but the electronic oil pressure gauge I bought from Holdens, along with a sender unit and a T adaptor so that I could retain the original oil pressure switch also. I also bought a bezel from them at the same time that was the identical profile to other the existing Morgan gauges. Easy to change over. Might have the details somewhere, I'll have a look but I'm sure you could find it on Holdens website.
Current car has Jaeger gauges and even in 1934 came with oil pressure and oil temperature gauges, Rev counter, speedo, trip, temp gauge, the works.. But no fuel gauge..the jack handle extension is nicely calibrated as a dipstick! ATB! Steve.
