Morgan Aero 8
5 members (+8Rich, Moggo, BobtheTrain, Sir Percival, BillHart), 487 guests, and 42 robots.
Adam12 68
+8Rich 67
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,385
Members9,215
Rbt Aero8, Salmon, stevends
#302993 07/09/15 06:41 AM
Neilda Offline OP
During a quick drive at the weekend - reasonably warm, top down, blue skies - my speedo and rev counter became fogged up... very odd. Never had this happen on any car before.
Fogged up to the extent that from the 10 o'clock to 2 o'clock positions I couldn't see the dials at all.
It cleared of it's own accord once home.
Why might this be?
+8 4.8
Neilda #302994 07/09/15 06:49 AM
I had this, but only on rainy days. Either turning on the head lights (and hence the bulb in the gauge) clears it as does time. I think it quite common....at least on the older trads.
Some thoughts here (GoMoG).
Neilda #302999 07/09/15 06:59 AM
Formerly known as Aldermog
Caused by humid air in the instruments and a temperature change, the humid air is the result of the the wonderful August weather!
Occasionally a problem here with the Mog if left outside overnight, but in the garage, which is part of the house and although not heated tends to be warmer than outside, it isn't a problem.
The other solution is to live somewhere warm and dry where this wine is made.
Neilda #303003 07/09/15 07:03 AM
Neilda Offline OP
I guess the Morgan dials are more exposed than the dials on any other car I've had - they're fractionally closer to the elements.
I would live in France - happily. Apart from the government bit! smile
+8 4.8
Neilda #303036 07/09/15 09:22 AM
I've had it a few times on my S3 but it always clears itself pretty quickly and no obvious harm done after nearly 8 years!
Neilda #303059 07/09/15 10:19 AM
Happens regularly on my 4/4 in winter.
Neilda #322860 01/12/15 09:53 AM
You are supposed to modify them by drilling holes from the back, are You not?
Neilda #322943 01/12/15 03:13 PM
Even Vulcan Bombers had air tubes to the gauges to keep them mist free !!!
Neilda #350296 24/03/16 07:45 PM
Interesting test today. I can't get out in the Roadster tomorrow for a variety of reasons, so at tea time I fired it up and ran it to temp with the sidelamps on.
All four small gauges steamed up within a few minutes. This seems to indicate that the misting is not related to cold air circulating in the cockpit. Because the garage, although not warm, was about 6 degrees.
Neilda #350309 24/03/16 09:02 PM
Dave it relates to warm, moist, air inside the instrument and the glass being colder. The mist (in effect dew) then forms on the glass. It is exactly the same as taking a cold beer bottle out of the fridge and into the warmer air. The moisture in the air condenses on the beer bottle.
Turning the lights on only warms the air inside the instrument faster than the warmth generated by the electronics alone. The only real solution is to bring the glass up to the same temperature as the warm moist air inside the instrument as soon as possible. A hermetically sealed instrument with dry air inside would also be an answer.
On the Morgans the bulbs in the instrument are incandescent and therefore generate heat. LEDs are not dimmable without complex circuitry.
A hypothetical solution that has been discussed is running warm air in tubes from the heater system. If an aircon is fitted it would work even better as the aircon unit effectively de-humidifies the air.
