Morgan Aero 8
8 members (TalkMorgan, nestor59310, auster, RedThree, JonathanLand, PaulyG, jbk, TBM), 358 guests, and 38 robots.
+8Rich 102
John V6 60
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,184
Georgetoad, woolfie
Jappo Offline OP
Had my wheels balanced earlier today and noticed that the wheels have a rubber seal on the inside centre around the hub. The one on the drivers side front is missing.
Anyone know what they are there for?
Incidentally, all my wheels were in balance so the vibration I get between 80 and 90mph must be something else.
What sort of wheels
Wires/alloys?
4 wheel nut fixings or centre fixing
Normally wheels balanced off the car but could be other rotating mass could be discs?
Jappo Offline OP
2003 S1 Aero - 5 stud Magnesium OZs
If the car has studs then the hub centre is not involved with the security of the wheels you would never fit a wheel that cannot be secured and this would be an issue with a rubber fitting, it sounds like a dust shield for the wheel bearing, not any sort of an expert, best nip along to a dealer and ask one of the fitters, clearly the car drives around without it but dirt ingress would turn to a nice grinding paste and the bearing life will reduce.
Mag wheels are expensive and can hide damage but lack of true would show up on a balance machine, if the wheels wobble at set speeds can be due to lack of natural damping in the steering, this is called shimmy, on commercial vehicles it manifests itself at slower road speeds but that would be expected, look at the tyre treads, the rubber blocks need to work this can be associated with a lack of a steering damper, too much freedom in the top kingpin bush or worn tyres,
Jappo Offline OP
Given the car has only done 460 miles since September 2007 I'm beginning to suspect 50p piece shaped tyres - what do you think?
