5 members (RobCol, Scrambledsignals, Morganmike, Horror, teknome), 284 guests, and 41 robots.
+8Rich 93
John V6 49
Posts837,988
They are left-handed flange brackets tapered to fit the widget frame.
Originally Posted By John V6
Agree that is what they are
Indeed they are. I have just come in from the workshop, having drilled mine at the tops, where I have mounted a couple of Neodymium magnets to hold the tops of the sidescreens in place.
Thanks everyone, you've solved it again. The car has similar pieces installed that are of heavier material and are chrome plated to match the windscreen. I wonder if these are perhaps intended as spacers to go behind the chromed items and shim them into proper position?
Tom Morris
1972 Plus 8
1932 Super Sport "Beetleback"
1961 Morris Minor Tourer
1972 Triumph T120V
mop Offline
Appear to be draft extruders. My 94 Plus4 from the works came with black plastic ones. Replaced with SS from Hearts of England.
+1
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
As above from John Worrell at HoE Morgans. Replace the plastic part between the screen and uprights. Remember which way out the screws came, as they are not all the same length for good reason!!
