7 members (JohnHarris, RichardV6, Graham, G4FUJ, Alan Patterson, DJC, IcePack, SwissMogFan),
257
35
Posts837,992
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
They are left-handed flange brackets tapered to fit the widget frame.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Agree that is what they are Indeed they are. I have just come in from the workshop, having drilled mine at the tops, where I have mounted a couple of Neodymium magnets to hold the tops of the sidescreens in place.
Posts: 76 |
Thanks everyone, you've solved it again. The car has similar pieces installed that are of heavier material and are chrome plated to match the windscreen. I wonder if these are perhaps intended as spacers to go behind the chromed items and shim them into proper position?
Tom Morris 1972 Plus 8 1932 Super Sport "Beetleback" 1961 Morris Minor Tourer 1972 Triumph T120V
Posts: 11 |
Appear to be draft extruders. My 94 Plus4 from the works came with black plastic ones. Replaced with SS from Hearts of England.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
As above from John Worrell at HoE Morgans. Replace the plastic part between the screen and uprights. Remember which way out the screws came, as they are not all the same length for good reason!!
Richard 1976 4/4 4 Seater
