8 members (Carbuilder, sezznowt, Tresco, DCH, JMcL, dakri, James B W, Willowgreen320), 265 guests, and 71 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,760
Page 44 of 74 1 2 42 43 44 45 46 73 74
I was told by someone involved in Morgan racing that rear disks wer not effective on a road car as they are used too lightly if properly balanced. He strongly recommended that I stayed with rear drums.
I would agree taken my personal needs into accouunt. On the other hand if someone drives spirited, the rear drums become hot, and as they are self adjusting - and when cooled down friction can occur because the adjustment was over the point and makes them too tight.
That's the reason why some track enthusiasts I know changed to discs, as realized first with the Babydoll in a small series.
Ray Offline
People don't seem to realise that drums can work well untill they get to hot. But how many of us have got to the point where the BACK brakes are over heating IN ROAD USE?
Ray #303783 10/09/15 05:54 AM
Originally Posted By Ray
.....where the BACK brakes are over heating IN ROAD USE?
just watch any Dutch driver doing a downhill road in the Austrian mountains
hide
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
There's no doubt that the ARP4 is an interesting development, the combination of Cosworth engine and new suspension should be great and the cars look lovely, but I do hope MMC isn't placing itself at risk again of selling a car with a lack of development - P4SS, M3W, and 3.7 Roadster all spring to mind.
SFO Offline
are rear disc brakes so much heavier than drums?
I don't understand why having more braking capability is a 'problem', apart from additional unsprung weight?
thanks for the pics .. really good to see them progressing
SFO Offline
Originally Posted By Heinz
Cool Yokos AD08
what are the advantages and disadvantages?
SFO #303893 10/09/15 03:05 PM
Most of the braking in a car (or a bike) is performed by the front wheels. This is because under brakes there is a major transfer of vehicle weight to the front. This is why the front of a vehicle dips and the rear rises. If you stamp on the brakes, as in panic, there is a tendency for the front wheels to lock up because the weight of the vehicle has not had time to transfer and create the downward forces on the tyres for effective braking. Under correct controlled braking the brakes are applied progressively with increasing force as weight transfer increases the grip of the front tyres.
Because of the reduced weight on the rear tyres as the back of the car tends to lift you require less braking forces at the rear or you would lock up the rear wheels. Manufacturers go to a great deal of effort to get this balance between front and rear wheels correct. Usually smaller disks and callipers are used in all disk systems or less powerful rear brakes in all drum brake systems. Many light vehicles use disks at the front and the less powerful drum brakes at the rear. Drums also require lower hydraulic pressure and have the advantage of being very easy to use for handbrake systems.
Race cars often have a driver controlled proportioning valve to effectively limit the rear braking forces.
To return to the Morgan: It has been said that for road use rear discs would be so lightly used that if a car was only used on relatively short trips there may not be enough brake use to completely clear corrosion from the rear disks. The end result could be the build up of corroded patches on the rear disks that would eventually lead to uneven braking.
With a light weight car such as the Morgan rear drums are perfectly adequate for road use and cost less that rear disks (which would also need a separate handbrake system). For road use it is difficult to immagine the circumstances under which you would ever get any fade from the rear brakes. If you doubt me try touching the rear drums after a period of driving on a mountain road. I have and I can assure you that they do not get hot enough to cause fade.
Improved front brakes would probably be the first thing I would consider. Unless you constantly drive in a spirited manner wink or intend to get involved in competition, perhaps the rear discs on the AR P4 are more of a fashion statement than a necessity.
Just my idea smile
These build pictures are great - I must get a factory visit it some time soon. I think theses cars will be superb when done. They look good now!
A few more photos today. Not withstanding the pros and cons of rear disc brakes, getting access to the handbrake mechanism is certainly a big pro as you'll see from the photo!
The bulkheads are of alloy rather than stainless steel and have rather nice strengthening pressings in them...as do the front floor panels.
One photo shows the oil tank....mounted for a left hand drive car!
Jay, these shots are fabulous, please keep them coming. Thank you.
Norfolk Phil
2014 Sport Blue 4/4
1959 Frogeye Sprite
