2 members (DaveW, flyfisher), 109 guests, and 17 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
AlexCreasey
Originally Posted By John +4
Originally Posted By minikeefy
Nice as always!!!
"Your mission if you wish to accept it" is to do something similar for Front Suspension as I am totally bamboozalled.. as you know I have a 2002 4/4 and can only find a single grease nipple on the flipping thing...am I missing something?
Try this link
http://www.gomog.com/allmorgan9.html#Dynamics
The grease nipples face forward so when jacked up and on axle stands you should be able to see them.
Dave,
I took a pictire today to show this but my cars is covered in crud. Do you clean yours underneath as well?
Miine also has a grease nipple at the top of the king pin instead of the one shot oiler, you can see this by putting the front wheels on max lock & looking into the top of the wheel arch.
DaveW Online Content OP
OP Online Content
John - I don't go mad underneath but give it a wipe down now & again. Sad eh? Old habits die hard. laugh2
Dave, you have angled grease nipples there on the sliding pillar. On mine (2004 built 4/4) they are straight, and almost obstructed by the damper - if I had mounted the AVOs with the adjuster like yours, there would be no way to get a grease gun on without removing the damper. Perhaps I should change the nipples sometime.
Also I don't have a nipple on the top of the spring.
Nigel
OP Online Content
Nigel - do you only have one nipple each side??
When my stubs were changed to the later spec, the bill included nipples. I don't know what the original spec was.
Yes, I can only find one nipple - on the front surface of the stub axle body, and it faces forward.
I'll post my photo then to give you sleepless nights!!
hide viking shocked2
Dave you star.....I did not realise that you had added this to the post...Many thanks for letting me know Nigel..
I will check it out tomorrow!
Keith
OP Online Content
Keith, I use the 'Active Topics' tab to keep updated on what's going on. Are you using the Forum List?
