8 members (Anonymouse, Chris Cosher, Alan Patterson, bmgermany, Luddite, Julian BB, Vansrv6, JohnHarris),
272
Topics49,899
Posts838,033
Posts: 37 |
What thickness steel is used for a door re-skin?
Martin R
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
What thickness steel is used for a door re-skin? Surely the doors are made of aluminium.
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Originally they were steel
Posts: 676 |
What thickness steel is used for a door re-skin? Contact Steve at VSM, I'm sure he could tell you.
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 37 |
Hi my 69 Morgan has an nasty cheap car horn fitted, any idea what the factory horn should look like and where is it mounted
Martin R
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Morgans have always had nasty cheap car horns fitted!  Mine is under the front cowl box, but I don't think it matters where they go, so long as they aren't where too much road dirt and wet can get to it.
Posts: 3,643 |
Hi Martin, recent Morgans have been fitted with plastic horns, in front of the radiator. To see the horns go onto Holden Vintage and Classic car parts, they are part numbers 080.468 and 080.469, on low note the other high note.
I hope that helps.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
My Lucas data sheets tell me that a Lucas 9H horn was fitted to a 1969 4/4, I'm sure Google images will provide the necessary pictures!
Mounting, my 1972 4/4 has it under the cowl box and my 1968 Plus 4 has one on the bulkhead!!
Door skins: the old steel ones measures out at 0.036 or 20 SWG
Not sure what the ally equivalent is, slightly thicker I suspect
Cheers
Arwyn
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The 4/4 comes with one horn but wired for two. I picked up a pair of new Lucas horns off E-Bay.
Posts: 37 |
Thanks for your help, 20 SWG looks right. The nasty horn is on the bulk head so I guess that's the right position.
Martin R
