7 members (IcePack, BLUE+4, Ruut Bianchi, Paulxj, JMcL, Burgundymog, Image),
251
Topics49,905
Posts838,100
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Having noticed wing corrosion due to galvanic action, (aly wings, steel nuts and bolts) creeping out from under the running boards strips i decided it was time to get the wing resprayed. I then set about removing the strips. However the nuts and bolts were nearly all rusted and had to be snapped off from underneath. (gently fatigue the the bolts with mole grips by rocking in the direction the strip is running).
After re-spray, Instead of replacing them i used 3mm Aluminium Rivnuts (M3) and stainless machine screws (M3 pozidrive countersunk 16mm ) so there was no steel in direct contact with the wing, ( this will involve drilling the holes to 4.9mm) I also used double sided trim tape under the running board strips to create a seal, the screw heads were greased with Corrosion Block Blue Grease, the rubber re-fitted and then spayed Satin Hammerite underneath followed by underseal. I did consider aluminium rivets but Rivnuts allow you to undo the screws.
To save you the expense of a respray job like me, I think its worth removing the rubber strips now and then to check the bolt heads for corrosion and possibly grease them or soak the channel in ACF50. Its not tricky to remove and replace the existing rubber, strangely, you may find the rubber longer or shorter when you replace it but this is easy to adjust by carefully pushing the (using a blunt screwdiver) in the appropriate direction.
If you decide to buy new strips (at around £50 a pair) you will still have (mild?) steel nuts and bolts in direct contact with the wings, that is why i saw no point in going for new strips as the existing strips were ok. Be careful when handling the strips as the aluminium is very pliable. Hope this info helps…. John K
1993 T16 +4 Lancia Blue.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Useful information. Thanks John.
Posts: 2,583 |
seals + direct do running board rubbers if anyone needs them.
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
When I replaced my wings, I didn't bother refitting the strips. Less places for mud to gather! More bodywork to polish!
Richard S 1993 4/4 1966 VeloSolex
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
It's a very worthwhile job, even on newish cars. Here are a few pictures to assist: http://www.talkmorgan.com/ubbthreads.php/topics/253544/1
Wish i had found that thread before i started Dave, only difference with my issue was the paint bubbling, never had the rubber bulging. Agree that lifting the rubber to check is an easy job worth doing before corrosion sets in, takes just a few minutes per strip.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
In my case I was thinking a frequent dose of ACF50 to seep under the channels might prevent the need for removal. Not sure it won't affect the rubber though?
Posts: 14,009 |
Mine's starting to bulge. Something I need to get my hands on sooner than later.
The rivnuts are an interesting approach. Do they sit pretty flush to the wing.?..I was wondering if the running strips end up sitting slightly off the wing.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
You can get rivet nuts (aka Nutserts) with different thickness of flange, Jay. There are some which are supposed to give a very low profile, but if there's a decent thickness of aluminium to mount them into, a countersunk version is also available. See the Torque Control website
Posts: 8,646 |
When I replaced my wings, I didn't bother refitting the strips. Less places for mud to gather! More bodywork to polish! Couldn't agree more. I don't get the point of the strips. After all, you don't want people treading on the wings. The strips are only likely to encourage this. In any case, the wings look better without them IMHO - it's one more thing to cause unnecessary problems.
Giles. Mogless in Paris.
