8 members (Morganmike, Grumpy2, DJC, Oliemog, Pyewacket, Graham, G4FUJ, Lordofthewings, Julian BB),
143
42
Topics49,911
Posts838,143
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
Report: Very knowledgeable (and nice) mechanic from Perranwell came round last night and managed to get it started. Seems it was not the ecu but a problem with a camshaft sensor. Laptop diagnostics flagged up "camshaft out of phase". We removed the two cam position sensors (simple hall effect triggers)at the back of the rocker covers, wiped them with a rag and re-installed them and re-connected the electrical connectors. Bingo, it started and ran fine. I can only guess one of the electrical connector pins was not making contact. The car was running perfectly when I last used it after an 800-miles trip to the Loire in early September but I had not started it since then due hospital/knee replacement op'. Whether leaving it for six weeks (on trickle charger) could have caused the "out of phase" problem I've no idea. Maybe I'll carry a spare cam sensor in future.
Posts: 5,210 |
Welcome Paulxj to TM. Apart from that starting problem hope you're enjoying Morgan ownership.
Which part of the North West are you?
Posts: 5,210 |
That sounds like great service from Perranwell. Well done to them. Hope you get out again to enjoy it. Perhaps Perranwell could have replaced your knee for you?
Posts: 347 |
Thanks Griffo for sharing that. It is always useful to learn about things that have happened with other cars. Mine has failed to start a couple of times but looking at the immobiliser tell tale shows that it was a communication problem. Key out and back in and all was well (so far!)
2014 +4, Le Mans Blue / Magnolia "Meg" the Mog
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Sounds like great service and pleased to hear that you and the MOG are back up and running.
Richard 1976 4/4 4 Seater
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
I can feel a GDI owners hints and tips coming on.
I wonder if the ECU is a standard Ford unit?
Posts: 5,210 |
I wonder if the ECU is a standard Ford unit? We need to start a movement for bringing back starting handles.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
It's something else to worry about with a new car. There's been 'another' GDI ECU fail on TM, but I can't remember who it was.
.... Snip
It really does make me twitchy about ordering a new car, especially when other issues like headlamp cowls are still happening, and the handbrake cable design, which could so easily be sorted.
.... Snip Just another reason to add throttle bodies and a cam to the yellow rocket Dave. Either that or a little engine swap to 2.5 litres
But by the time I add stainless wheels and a mohair easy up................£££££££££££££££
It's a conundrum.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
It's a conundrum. No, it's a Morgan
