8 members (Graham, G4FUJ, Simon, SwissMogFan, Julian BB, +8Rich, RichardV6, John V6, Laurens), 298 guests, and 32 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
JVS Offline OP
Time to put the new clutch pack onto the engine.
First clean up the flywheel bolts
Attach the Flywheel to the engine shaft
80 ft lbs of torque on the bolts
We have a tool that can hold the flywheel from turning as you torque the bolts down.
It's a Snap On Tool A-144 Flywheel holder
Next up is the pressure plate - it has a label on which side faces the flywheel.
****Next is a critical Step **** (sorry no picture)
Using the pilot shaft ailment tool to center the clutch plate splines on the crankshaft.
Note: Without it being aligned to the pilot shaft correctly when going into the pilot shaft, it could damage the previous installed pilot shaft bushing!
Metric Clutch Alignment Tool need to do the job right
Torque pressure plate to flywheel at 25 ft lbs
the pilot shaft bushing that was installed with a small press before it was installed into the compensator part of the engine.
When bolting on the transmission tunnel:
No Lock tight to be used on these bolts
Be sure to use a small lock washers
Torque to 28 ft lbs
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
Interesting. Looks like there was copperslip or similar on the flywheel bolts.
My flywheel holding tool is a bent valve! Works a treat and very cheap...
My clutch centring tool is a handled rod and a selection of screw on and slide on bits. Never met a clutch I could not adapt it to and it's had plenty of use over the years.
My last clutch alignment tool was a Snap-On strong bar handle and insulating tape.
What about the story i hear of putting in the clutch the other way around in a 3 wheeler
JVS Offline OP
When finishing up the install the only issue we had to work through was bleeding and building up pressure in the new cultch slave line. We used a brake bleeding system that built up some sucking vacuum pressure to help bleed the line to get the brake fluid down into the cutch slave. We also found a tiny piece if dirt right in the end of the bleeder that didn't help either.
Up and running now.
JV Sclafani
Boca Raton, FL
After talking to MORGAN regarding clutch pricing, i am puzzled why you change the flywheel at the same time.
http://www.moss-europe.co.uk/ sell clutches and flywheels for Mazda MX5`s at quite a saving over the price of a local dealer, if anyone is interested.
From what I gather the clutch used is NOT a Mazda. The Miata clutch assembly with their lightened flywheel looks nothing like the pictures JV has posted.
I think that Morgan has used the Miata trans, but has used their own flywheel and clutch setup. I think JV referenced Volvo as Morgan's possible source for the assembly he installed.
So I doubt that Miata parts are going to work. I could be wrong though...
Dan
JVS Offline OP
The flywheel and clutch pack is Morgan designed and sold only thru Morgan service department.
The only Mazda part is the sealed case and everything behind the the Volvo sourced clutch slave unit. We thought it looked like a BMW motorcycle clutch setup of some kind and seeing that Morgan does have a relationship with BMW it could well be.
JV Sclafani
Boca Raton, FL
