1 members (+8Rich), 284 guests, and 32 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
Working on a 54. This is a frame up resto. I am now working on the wiring. The car is currently a positive ground. So here are some questions:
1) Would you change the car to a negative ground?
2) Would you put in an alternator or keep a generator?
Thanks,
Ben
This comes down to a choice of originality over function. Personally I would change it, but buy one of the modern alternators that are assembled into a retro looking dynamo casing.
Martin (Deano)
My personal choice if doing a comprehensive restoration would
entail retention of original specifications/components if at all feasible.
Only one man's opinion however.....
Bert & B1800
To me, it depends on what you are going to do with it once it's finished.
Drive it - then convert to alternator, doing as Deano suggests
Show it - then keep it original
Sell it - then keep it original
The only other factor that comes to mind would be if the car has individual historical significance, in which case keep it as original as possible.
E
E
Agree with what Tim said.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
Positive earth is a pain. Just about any bit you add to a car is or expects negative earth.
I'd convert like a shot, one bit of originality that makes no sense and cannot be seen either as without a voltmeter, you'd never know.
Interestingly to note, all Morgans until the early 30s were negative earth. Then the fad for positive earth came in on most if not all manufacturers, Morgans included. I don't know if it is true, but my father said it was an anti-corrosion measure, although since it didn't work, and negative earth is much more convenient, manufacturers eventually reverted.
Gone to Porsche
Gone to Porsche
+1
Ben
Tim and others are correct. If you want to drive the car and enjoy ownership then use an alternator (whether you use one that looks like a dynamo or not is entirely up to you) Only use a dynamo if want to show or sell it, and even then convert to negative earth.
Using an alternator will commit you to negative earth (ground) . This will also give you a lot more choice of electric fuel pumps, and certain other accessories, positive earth versions are becoming very hard to find now.
Andy G
1999 +8 , Indigo Blue.
Another vote with Tim. Can't even add anything, other than this thread has also been historically informative.
Thanks for all the input. Since this car will be a driver not a 'trailer queen' I plan to convert it. I will keep the original generator and the voltage regulator so if the next person wants an original, they can convert it back.
I will be going with an alternator rather than a generator. I think it will give me more options, such as driving lights and a radio.
So now on to the hunt to find parts and try to make it all look original.
Ben
