4 members (andymog1, Image, DJC, John V6), 239 guests, and 36 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,119
Originally Posted By agrajagg
'07 with 1596 miles on the odometer. I just replaced the steering rack & pinion ass. and now I am realigning the suspension and Holly Flying Spaghetti Monster! All the anlges are off on all four corners and any ajustment other than toe looks to involve some disassembly. Any tips or tricks out there?
Way too technical for me cozychair
Best advice is to wait until Cerealsurfer comes along or contact the factory (www.morgan-motor.co.uk)
Retrobate
Retrobate
Thought this was the Crimbo version? rofl
Cheers,
No, that would be the Invisible Pink Reindeer
Last edited by Paul Hurst; 22/07/09 10:22 AM. Reason: missed first (relevant) quote
Can you sketch up the angles you are talking about??
I believe later models moved to fixed suspension geometry. Only the earlier cars have the fully adjustable race suspension.
Not sure what adjustment is available to you.
With his Noodly Appendage guiding my hand I have finally finished the alignment and gained some valuable experience. No way around having to disassemble in order to make any adjustment other than toe. One full turn is roughly 1 degree of camber on the rear suspension. The front castor was about 2 turns to 1 degree and camber 1 to 1. It was difficult but that's what makes life interesting.
Praying the Pirates return so I can have a break from this heat. Ramen
