11 members (chanteclair, Detlev V6, RichardV6, Jon G4LJW, Chris99, TalkMorgan, TeddyAds, Scrambledsignals, mph, DCH, +8Rich),
259
Topics49,910
Posts838,136
Posts: 29 |
The inside of my chrome bumpers are going rusty and need attention. Is there anything I can do to treat them or do I need to send them to a chroming specialist. I've tried using WD40 and a wire brush but this doesn't seem ideal. Regards Phil
Posts: 1,947 |
Firstly, never, ever use WD40 for this job. Reason being, it is a water attractor and works as a water displacement fluid by virtue of the water falling away with the excess WD40. It's also a rubbish lubricant as well.
If the inside of the bumper is not plated, my temptation would be to use a phosphoric acid rust treatment (Kurust is one) and then paint it black, or body colour.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The insides are never well finished Phil, and even a rechroming won't provide long term protection. When I had my front MGB bumper rechromed many years ago I asked about a guarantee and the chromer just laughed!
Remove your bumper from the car. Protect the outer surface - masking tape or similar, and place on an old towel. Then probably a drill attachment will be best on the rust first - use eye protection.
Then follow Martyn's advice with a rust converter if necessary. Follow that with an etch primer. When that's dry - my favoured finish is just silver paint - wheel paint will work, as will any standard silver. Originally they seemed to have had a rough hammered silver finish, which is not easy on the eye.
Posts: 29 |
Many thanks guys. Really useful advice and greatly appreciated.
