0 members (),
257
38
Topics48,336
Posts812,904
Members9,203
Posts: 28,413 Likes: 177
Posts: 28,413 Likes: 177 |
Ken, do you think your car is overheating? A different tack, and probably cheaper and easier than Waterless Coolant would be to add Water Wetter - quite common with V8 (Morgan and other marque) owners over the years. This would also mean, should you have a coolant leak, you can just add water/antifreeze. If it's not been done I'd recommend flushing the rad and block, before doing anything else...
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 11,854 Likes: 137
Posts: 11,854 Likes: 137 |
orry guys my last note was addressed to Bobthe Train's msg at 08.15, since followed by positive words, thanks Bob Using the quote facility will enable you to place your comments in the correct context
Posts: 853 |
Tim
OK but this site is c**p at telling anyone how to use it. I can't find how to use "quote" facility
Ken
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 5,210 |
Tim
Ken Ken - hit the third button along below the message you want to reply to marked "quote".
Posts: 6,825 Likes: 59
Posts: 6,825 Likes: 59 |
Tim
Ken Press the "Quote" button at the bottom ot the post. Oops! Beaten to it.
Tim
Ken If you look at the box where the post you are replying to is displayed, you will see some buttons, one is marked 'Quote'. Click on that and the text is copied down into the reply panel, surrounded with the formatting tags to ensured it's displayed properly. Instructions on how to use the forum are available under the 'Forum Help' link on the top menu.
Posts: 2,774 |
Ken, for a relative newbie I don't think you have made a good start on here!
Upsetting the guys by making demands and being rude probably isn't the best way to seek help from what are a bunch of very experienced and friendly owners, at least I have always found them so. But then I don't insult them by calling them pillocks.
I doubt you'll get much help on here with that attitude, and I would think an apology is due.
Posts: 391 Likes: 5
Posts: 391 Likes: 5 |
The search option does indeed throw up a whole lot of good information. See the search box at the top left of the page.
"this means the end of the horse-drawn Zeppelin!" - N Seagoon
Posts: 853 |
Tim
Ken If you look at the box where the post you are replying to is displayed, you will see some buttons, one is marked 'Quote'. Click on that and the text is copied down into the reply panel, surrounded with the formatting tags to ensured it's displayed properly. Instructions on how to use the forum are available under the 'Forum Help' link on the top menu. Check??
Posts: 853 |
Tim, the word check is mine
Ken A
