Morgan Aero 8
8 members (nestor59310, TalkMorgan, auster, RedThree, JonathanLand, PaulyG, jbk, TBM), 360 guests, and 36 robots.
+8Rich 102
John V6 60
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,184
Georgetoad, woolfie
#33557 16/08/09 10:55 AM
Jappo Offline OP
Hi all, I reported a while back that my S1 had vibrations above 70mph. They have got worse over the last 2000 miles but here's the interesting diagnostic: turn steady left and it goes away, turn steady right and it gets worse.
Wheel bearing(s)?
What do you think, and if it's a wheel bearing anyone know how much a dealer will cost to fix it?
Many thanks - Jap
Jappo #33596 16/08/09 07:20 PM
Ivo Offline
TM Photographer of 2011
If it behaves as described, it could be the left wheel bearing. Replacing is usually a 30 minutes job.
But it's hard to say from here... because, rather than vibrations, a worn wheel bearing produces a "wheeeee" sound that changes the tone with speed.
sunny
1998 +8 (permanently out of service frown )
Ivo #33674 17/08/09 11:03 PM
Jappo Offline OP
No "wheee" sound, just, quite serious, vibrations above 70 mph.
Jappo #33676 17/08/09 11:19 PM
Wheel bearings, if you have a basic mechanical knowledge are really easy to do. Either that or it could be off camber? maybe worth getting wheel alignment checked (usually £20) and will eliminate that as a problem first, cheaper than bearings if it is them.
usually wheel bearings go at same time though.
are uou talking wheel alignment or balancing? For a vibration like this I would think either balancing or maybe a dmaged tire (would also show up while balancing the wheel) especially if the car had been park for a long time without moving
