8 members (Simon, TalkMorgan, auster, TBM, nestor59310, RedThree, JonathanLand, PaulyG),
374
Topics49,914
Posts838,185
Posts: 76 |
Hi all, I reported a while back that my S1 had vibrations above 70mph. They have got worse over the last 2000 miles but here's the interesting diagnostic: turn steady left and it goes away, turn steady right and it gets worse.
Wheel bearing(s)?
What do you think, and if it's a wheel bearing anyone know how much a dealer will cost to fix it?
Many thanks - Jap
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
If it behaves as described, it could be the left wheel bearing. Replacing is usually a 30 minutes job. But it's hard to say from here... because, rather than vibrations, a worn wheel bearing produces a "wheeeee" sound that changes the tone with speed.
 1998 +8 (permanently out of service  )
Posts: 76 |
No "wheee" sound, just, quite serious, vibrations above 70 mph.
Posts: 157 |
Wheel bearings, if you have a basic mechanical knowledge are really easy to do. Either that or it could be off camber? maybe worth getting wheel alignment checked (usually £20) and will eliminate that as a problem first, cheaper than bearings if it is them.
usually wheel bearings go at same time though.
Posts: 137 |
are uou talking wheel alignment or balancing? For a vibration like this I would think either balancing or maybe a dmaged tire (would also show up while balancing the wheel) especially if the car had been park for a long time without moving
