0 members (), 339 guests, and 28 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
#337302 01/02/16 11:33 AM
St Eve Offline OP
My navigator has just told me he will not be available for a planned run tomorrow, so I have no-one to read my tulip diagram. It occurs to me that there ought to be a device containing a couple of cylinders set a small distance apart whereby a set of route instructions can would round the bottom cylinder, affixed to the top cylinder, and the paper containing the route advanced by turning the top cylinder. The whole thing to be attached somewhere within easy view of the driver. Don’t rally co-drivers have something like this?
So, before I go trying to make one, does anyone know if such a device exists? Failing that, it'll be setting coordinate-based waypoints on the satnav - which is a bit of a fag.
St Eve #337305 01/02/16 11:43 AM
They use devices like that in the fifties on Rallies.
Not sure the practical of reading and trying to drive.
St Eve #337306 01/02/16 11:43 AM
Sounds like you're gonna spend the afternoon in the shed strapping two toilet roll holders together! hide
Regards
Alan
AP08 MOG
St Eve #337309 01/02/16 11:51 AM
Think I'd try and make one if these are anything to go by!
http://www.rallymanagementservices.com/products/md-roadbook-reader
http://www.thesignaturestore.co.uk/shop/4566396525/722-roller-map-boxed-set/3164325
(both extremes I know but all that a quick search came up with. I knew that Moss and Jenks used one)
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
St Eve #337310 01/02/16 11:57 AM
Ray Offline
Mad price. shocked2 spend
St Eve #337313 01/02/16 12:06 PM
Ray Offline
Most modern navigators have pace notes written in book form or stapled sheets that they turn over.PS not so easy when the top is down.
St Eve #337316 01/02/16 12:25 PM
My navigator used a ring bound book. He could correct as we went as some stages were used more than once and often the notes need changing as conditions change. The biker world have plastic box versions of what you type for a fraction of the cost of the item in the link and I have seen some nifty home made versions housed in a plastic sandwich box with wood dowels and a glued in clear plastic window.
BR Colin
St Eve #337317 01/02/16 12:26 PM
You can get the simple version from here.
http://www.vmccshop.net/p/5948/route-roller-oxford-products
I use to use one on my classic BMWs in the good old days. They work well....as long as you remember to roll it on at every junction!
St Eve #337318 01/02/16 12:29 PM
2008 4/4 1.8 Duratec
St Eve #337319 01/02/16 12:29 PM
crikey John, great minds eh...
